04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
How big...
Old Jun 6, 2009 | 06:21 PM
angelic0-'s Avatar
Default How big...
tires are you running without leveling kits and such ?
I am running a 11/2004 6.0 Gasser 2500HD
Could i fit my Toyo Open Country A/T 315/75R16 without having to cut anything ?
OR even my 33x12.5 R16.5
Old Jun 6, 2009 | 06:38 PM
bobcat67's Avatar
not without serious rubbage, 305/75R16's are the biggest i've seen on a stock 2500HD and they rubbed pretty bad with the stock wheels, so any wider wheel with a different offset is usually going to rub even worse, 285/75's are pretty standard on em with little to no rubbing
Old Jun 7, 2009 | 08:23 AM
angelic0-'s Avatar
i recall the rims being American Racing some wider stuff...
would a leveling kit be ok to run 315/75 ?
Old Jun 7, 2009 | 01:23 PM
2500HeavyDuty's Avatar
you can get 35's but it all depends on backspacing and width of the tires.
if they are too big crank up the tortion bars, or you can cut the fenders a little bit.
GMFullsize Forums - View Single Post - show me how you trim
Old Jun 9, 2009 | 05:36 AM
angelic0-'s Avatar
For now i just put my 33" under, the fit nicely, but i need to crank the torsion bars...
shouldn't be all that stiff on the truck only having 19000 miles on it
Old Jun 9, 2009 | 01:24 PM
Rttoys's Avatar
Just cranking the t-bars and triming the plastic inner finder wells, I started out with the 285/75-16 on stock PYO's, then went to 305/50-20, now I have 305/55-20. Once they are trashed I'm going to the 285/70-17 on H2 Hummer wheels.
Old Jun 9, 2009 | 05:28 PM
them 20 in tires get expensive dont they
Old Jun 10, 2009 | 07:17 AM
Rttoys's Avatar
****-ya and they are HEAVY too....for the good one's.
Old Nov 6, 2009 | 05:09 AM
Preacher's Avatar
I've got 325/60R18's on Eagle alloy 18 inch rims, and that comes out to a 33.4" tall, 12.8" wide tire. They rub slightly at full lock, something I can deal with.
Old Mar 10, 2010 | 06:20 PM
tnduramax05's Avatar
im running 315 75 17 on a 05 just cranked torsion bars and plastic trimmed a little and they dont rub unless im flexing it pretty bad
