2000 7,3 PSTD RUNNING BAD. (HELP)?
Old May 29, 2009 | 06:29 PM
tony ramsey's Avatar
Default 2000 7,3 PSTD RUNNING BAD. (HELP)?
Code #p1211
#p0541. also when going up a hill i have to push overdrive to get any real boost of power. any help with fixing the code reading is appreciated...THANKS
Old May 31, 2009 | 01:47 PM
Superstroker10's Avatar
do you have a chip on your truck?
i believe that is an icp lower than normal/demanded code. might have a weak hpop
P1211 ICP Not Controllable - Pressure Abow/Below Desired
Last edited by Superstroker10; May 31, 2009 at 01:47 PM. Reason: Automerged Doublepost
Old Jun 1, 2009 | 12:15 PM
CSIPSD's Avatar
Originally Posted by tony ramsey
Code #p1211
P0541 is the intake air heater, you must have deleted yours...
P1211 is ICP pressure, normal code (most of the time) for a chipped truck.
What mods? Gauges? What are your readings? Would love to help, but the codes dont tell much.
1997fordf350
Jan 15, 2015 06:12 PM
Oct 30, 2014 08:10 AM
