Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
tractor hard to start
Old May 25, 2009 | 06:30 PM
codys's Avatar
Default tractor hard to start
ive got an old long 460 or 510 not sure which. it runs good but to get it to start every time you have to use starting fluid. somebody told me that the timing was prolly off. what do yall think?
Old May 26, 2009 | 08:21 PM
JKM's Avatar
JKM
Does it smoke white once it is running? Could be that it is old/tired, injectors could need new tips, low compression ( starting fluid can break rings/ring lands) Some old tractors were just hard to start because of a crappy design. we used to have an allis chalmers 190, anything less than 10 above freezing , and it was HARD to start, but there was nothing wrong with it , that's just the way it was.
A compression test would be a good start IMO.
Old May 26, 2009 | 09:17 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
timing will do that. i dont know about long but my zetor you can retart and advance the pump
Old May 27, 2009 | 04:21 PM
bosslady's Avatar
posted on wifes
Old May 27, 2009 | 04:27 PM
codys's Avatar
dang i hate sharin a computer......but it dont have any white smoke and it ran great till we took it to a guy to work on. im startin to think the idiot screwed up the timin. it seems like it dont have quite as much power now. i guess ill try the timin first. i need to get this thing fixed as soon as i can. im just hopein it will run the hay mower and roller this weekend.
Old May 27, 2009 | 04:38 PM
diesel pap's Avatar
does it pop and miss awhile till it warms up at higher rpm
Old May 27, 2009 | 05:10 PM
codys's Avatar
no it doesnt. once it starts it sounds fine...just seems not to have quite as much power.
Old May 28, 2009 | 08:12 PM
DuramaxBen's Avatar
Does this particular tractor have a lift pump?If so try that it was what was wrong with our tractor and it perked it right up.Otherwise injectors or the fuel pump itself might be off timed.Check the lines and the fuel filters as well and use grease on the seals it seals them up better.
Old Sep 27, 2009 | 08:16 AM
codys's Avatar
finally got it fixed. ended up havin to replace a piston and the rings but its runnin like a new one now
Old Oct 22, 2009 | 03:58 PM
codys's Avatar
well it ran like new for a little bit then a valve in the hydraulics messed up and we got that fixed now the starter is messed up and gettin rebuilt so maby it will run right after this
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
