Nissan Patrol GR 2.8 TD trouble
Old May 22, 2009 | 11:54 PM
angelic0-'s Avatar
Default Nissan Patrol GR 2.8 TD trouble
Hi all.. me once again...
Now i'm having trouble with my "other" diesel...
It's symptoms are as if someone pulled the key out while i was driving.
As of now i've checked the following;
There is fuel in the tank.
Fuel gets to the fuel filter located on the passenger side of my truck (LHD).
Pulled off the tube that leads to the pump and pushed the prime button and fuel gets through.
Pumped 500ml of fuel through the filter and into a bottle, put the hose off the pump into the bottle in order to make the pump suck it up and i get no suction.
Put everything back together and opened for one of the injector and the fuel doesn't get through the pump.
Recharged the batteries to 13,7V and they're waiting for the next action.
What could be wrong?
I noticed there is a aftermarket Anti-Theft system installed although i have no remote for it and i suspect the immobilizer on it to be faulty but i'd like to have other peoples opinions here as well.
Oh, i forgot to mention, it cranks over... just doesn't run...
Old May 23, 2009 | 02:04 AM
biged681985's Avatar
idk the type of injecter pumps those have on them, but maybe it has went bad. if it was a thing with the security system, i would think it would of had some warning sirens or something that would be goin off to cause the pump not to work, or not crank. good luck with the seacrh to figure it out
Old May 23, 2009 | 09:23 AM
angelic0-'s Avatar
If i'm not mistaken the immobilizer on the antitheft system cuts out with the shutoff solenoid.
i think the siren might have been removed or that module might only include a immobilizer
Old Jun 7, 2009 | 12:08 PM
MRaynor's Avatar
Any update?
Old Jun 18, 2009 | 10:05 PM
wildbill's Avatar
Last activity was yesterday. Maybe bumping the thread will get some attention.
Mar 9, 2015 09:44 AM
Dec 18, 2014 03:25 AM
Dec 17, 2014 04:20 PM
Nov 26, 2014 01:40 PM
Nov 11, 2014 04:10 PM
