1990 Cummins wont run
Old May 10, 2009 | 06:43 PM
sjrvan's Avatar
Default 1990 Cummins wont run
I have a 1990 Dodge w350 with the 5.9L cummins. In January truck started chugging and blowing white smoke. Had to reprime the system to get it to start, still didn't run right. Replaced the mechanical lift pump and it ran for about 2 weeks, and then started all over again. Dropped and cleaned the tank,thought that was the problem. Still would not run unless I reprimed the fuel system and then only ran for a minute. Checked the lift pump and noticed that the lift pump would not pump fuel while turning the engine over. Took the lift pump off and pumped it by hand and got fuel. Cam shaft lobe shot ?
Old May 10, 2009 | 06:44 PM
94cummins12v's Avatar
eather that of you got a defective pump
Old May 10, 2009 | 06:47 PM
sjrvan's Avatar
Default Pump
It is doing the same thing it did before I changed it, mechanic told me that he thought the lobe might be worn, thinking about going to a electric fuel pump. The pumped worked when I pumped it by hand ?
Old May 10, 2009 | 06:50 PM
dont know why it would be worn, how often was the oil changed? how many miles are on the truck
Old May 10, 2009 | 06:53 PM
sjrvan's Avatar
200,000, he said that he has seen semi tractors that only had 140000 and the mechanical fuel pump had worn the lobe down and they had to replace the cam. Hate to spend another $95.00 and then have to replace it again, the last one only lasted two weeks.
Old May 10, 2009 | 06:55 PM
oh wow i had 280,000 miles on my truck before i melted the piston, the lobe was still a thousanth of an inch still in spec for a runnable lobe. i was actually thinking about getting a 12v pump as well to run with my mechanical just for safety reasons, but then again i have a fuel pressure guage
Old May 10, 2009 | 07:03 PM
sjrvan's Avatar
It is driving me crazy, it has not run since the first week of Febuary. I need to find a way to check the lobe to see how much lift it has. I would prime the system and it would run with the fuel filter off until it drained the fuel in the system. With the filter off no fuel was coming out of the filter housing.
Old May 10, 2009 | 09:30 PM
FastCR's Avatar
just my input, I did get a defective one from the parts house at first when I changed mine.
Old May 10, 2009 | 09:36 PM
RSWORDS's Avatar
Check for air leaks. The factory line likes to fall apart back at the tank and let in air. Also heard of lines rusting through. If its leaking down it has an air leak. The VE pump will pull its own fuel. Wont like it a whole lot but it will do it.
Old May 10, 2009 | 10:08 PM
ya your cam lobe should still be fine them lift pumps dont put alot of were on the lobe. your intake lobes should be worn more than you fuel pump lobe
