pump leak
Old Jun 11, 2007 | 04:48 PM
DBogo's Avatar
Default pump leak
theres some wet greasy crap on the back bottom area of my pump not sure if its diesel or oil. what one could it be and where could it be leaking from? i would inspect further but i figgured id ask because its a PITA to see right there
Old Jun 11, 2007 | 04:56 PM
Could be fuel. Have heard about pump seals comprimised due to ULSD.
Old Jun 11, 2007 | 05:25 PM
DBogo's Avatar
i will see if i can get a good smell of it, its real tough to get your hand in where its leaking
Old Jun 15, 2007 | 05:56 PM
DBogo's Avatar
its oil, for sure coming from behind the afc housing near that cover on the back, i cant tighten the two screws that hold the cover on anymore there tight already
Old Jul 6, 2007 | 10:06 AM
oldsmokey97's Avatar
since you have had a plate in your truck and have taken off the afc housing..... check it and make sure it is tight and snug on top of the pump.
My '94 that i had was bad about loosening up the 8mm bolt that held the housing on the pump. Therefore, oil would seep out slowly and make one heck of a mess.
Lance
Old Jul 6, 2007 | 05:14 PM
DBogo's Avatar
i just put the plate in a few weeks ago it was leaking before that
Old Jul 16, 2007 | 11:43 PM
Hammer's Avatar
You sure its not the oil return line for the P-Pump on the back thats leaking?.It also could be the quad ring seal which seals the pump to the front cover as they go bad all the time.When they go it will leak oil and travel along the bottom and down on the front suspension.To see if that it you need to lay under the left front of the truck and look up at the bottom of the p-pump and you can usually see where it originates from....Andy
Old Jul 17, 2007 | 05:44 AM
DBogo's Avatar
wheres the oil line?
Old Jul 30, 2007 | 11:38 PM
Johnny Cetane's Avatar
TTT
i was looking for this thread. think i have the same leak as you. looks almost as if it's coming from the seal between the main pump body and the governor assembly thought i might have heard something about the bolts holing the two peices together working loose and causing this leak. or is it the pump oil return line?
:pc:
Old Jul 31, 2007 | 05:52 AM
DBogo's Avatar
i still dont know where this pump oil return line is, theres not much room to look around right there but its dripping from the bottom rear of the pump down onto my motor mount
