1999 ford f350 7.3 powerstroke won't crank the engine, HELP!!
Old May 6, 2009 | 10:58 AM
dbrousset's Avatar
Default 1999 ford f350 7.3 powerstroke won't crank the engine, HELP!!
man, I am late to work.
Do't know if I will make it today.
So my truck won't crank the engine. I got full electrical power every where, yesteday it started just fine. I plugged it in last night ( heater) and this morning will not start.
There is a recall for the Camshaft Position Sensor, so I am assuming this is the issue.
This is the 3rd. time it has happened to me, thankfully not while driving.
I usually move some of the plugs and get it to start.
any ideas where the CMP is located so I can move it a little bit?
by the way I check all ignition fuses and all other fuses and all are ok
Old May 6, 2009 | 11:00 AM
Diesel Decals's Avatar
Its on the front of the block but moving it a little bit wont help
Old May 6, 2009 | 04:48 PM
dbrousset's Avatar
Yep, I unplugged it and plug it back and nothin happened.
Any other ideas?
I took it in to the ford dealer and indeed it was the Camshaft Position sensor, it has a recall so they fix it for $0.00.
Old May 7, 2009 | 04:32 PM
bigjake34452's Avatar
i hear that if you show proof of buying a CPS before you took it in for the recall they will reimburse you the price you paid, that is if you kept the receipt of course.
Old May 14, 2009 | 08:26 AM
MRaynor's Avatar
Any updates?
Old Jun 7, 2009 | 12:26 PM
MRaynor's Avatar
Since there have been no updates in so long, I'm going to assume that the problem is fixed and am closing this thread. The thread can be re opened if needed.
88 f350 7.3 idi
Aug 20, 2015 09:18 AM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
Dec 1, 2014 08:10 AM
