Contests And Give Aways The Diesel Enthusiasts Community Contests and Give Aways , NO Other Diesel Forum has given away as many Diesel Items as Diesel Bombers !
BD Flow Max Lift Pump Giveaway - May 1st - June 1st
Old Apr 22, 2009 | 05:08 PM
DB Admin's Avatar
Banned
Default BD Flow Max Lift Pump Giveaway - May 1st - June 1st
BD’s new Flow-Max lift pump has been designed to deliver ample fuel flow for more than 600 horsepower, yet is more compact, quieter and more durable than competitive products. Featuring a hard anodized aluminum body and proven gerotor design, the Flow-Max flows 150 gallons per hour (GPH) at 10 psi, and up to 165 GPH at full fl ow. It’s the ideal replacement for the OEM pump, which can fail even at the stock horsepower level and cause damage to the injection pump. The Flow-Max mounts to the frame using vibration isolators, and the kit includes all necessary hoses and mounting hardware.
• 150 GPH at 10psi, 165 GPH full fl ow
• Proven gerotor design reduces number of moving parts for greater reliability
• Poppet pressure regulator is superior to ball and spring designs
• 10% smaller and 16dB quieter than competitive products
• Covered by a 5-Year Limited Warranty
Please take a second to say thanks by signing up for the BD Newsletter - BD Power - E-Newsletter Sign Up
Old May 1, 2009 | 04:51 AM
DB Admin's Avatar
Banned
/me moved to open
Old May 1, 2009 | 06:59 AM
GRI's Avatar
GRI
sweet!
I am in
Old May 1, 2009 | 08:15 AM
cummins17's Avatar
How do you sign up?
Old May 1, 2009 | 08:18 AM
stkdram55's Avatar
your signed up by just posting in this thread, so that means you are in
Old May 1, 2009 | 08:39 AM
sidekick's Avatar
ill take a chance got a lot of time to work on truck out work for several months
Old May 1, 2009 | 09:46 AM
torquey's Avatar
thanks to you bd,im in.
Old May 1, 2009 | 10:10 AM
Red_Rattler's Avatar
High Tech Redneck
Awesome! THANK YOU BD-POWER for the great prize!
Old May 1, 2009 | 10:53 AM
MegaMan's Avatar
I'm in - Thanks DB & Thanks BD-Power!
Old May 1, 2009 | 12:55 PM
codys's Avatar
im in
