is this a true 887 pump?
Old Apr 18, 2009 | 12:32 PM
rallyit67's Avatar
Default is this a true 887 pump?
I am talking to a guy and he isn't sure if the pump came off of a 5 speed but it definately came off of a 97. the numbers read:
908 Bosch
4650887
0402736838
pes6p120a120rs7275
on the other pump i had seen the number 887 was on the 3rd line down not the second like this pump. can someone let me know if it for sure is a 215?
thanks
Old Apr 18, 2009 | 04:24 PM
MotorOilMcCall's Avatar
I'm pretty sure the 913 is the 215hp pump... The 887 is the 160.
Old Apr 18, 2009 | 04:47 PM
rallyit67's Avatar
the 913 is a 215 pump but so is an 887, but the pump im looking at has the number in a different spot than iv seen on a different 887 pumps so i posted to hopefully find someone on here that knows for sure that the 887 in that sequence i originally posted is the 887 im looking for
Old Apr 19, 2009 | 02:55 AM
xzaq103's Avatar
FormerVendor
Ill look at mine tomorrow.
Old Apr 19, 2009 | 09:45 PM
cummin_un_glued's Avatar
FormerVendor
the pump on my 94 auto truck is a has 908 like that on it
Old Apr 20, 2009 | 11:01 PM
xzaq103's Avatar
FormerVendor
heres a pic of mine.
Old Apr 21, 2009 | 12:45 AM
rallyit67's Avatar
Im still not totally sure since the line where yours shows the 887 his shows 838 as the last 3 but he has a 7 didgit number with 887 as the last 3 so im gonna call DDP tomorrow since they are in my neck of the woods.
Old Apr 22, 2009 | 02:54 PM
nmlakerat's Avatar
what was the end result
Old Apr 23, 2009 | 12:11 AM
rallyit67's Avatar
its not a 215 pump. to be a 215 the number "887" or "913" need to be where the "887" are in the pic that was posted but one of the other members. it must be in that set of numbers to be a 215 so im not gonna get the pump ill look around more.
Old Apr 23, 2009 | 02:02 PM
xzaq103's Avatar
FormerVendor
Did you try to pull the DV holder and DV to look for retard notches?
