injectors
Old Apr 15, 2009 | 11:38 PM
rallyit67's Avatar
Default injectors
would it be a good idea to get just the tips or just go for the injectors? Im on a budget and was looking between DDP 140hp nozzles or 435 injectors. any opinions on nozzles vs injectors or those tips or 435's in general?
I will be doing more mods so the truck can handle them but would like to get an idea on injectors first. Im looking to go to about 500hp hopefully at some point
Old Apr 15, 2009 | 11:54 PM
djwhonda92's Avatar
if you want 500Hp then you need to get the injectors. you can pull a lot more power out of the full injectors rather than the nozzles
Old Apr 16, 2009 | 12:04 AM
rallyit67's Avatar
so even though they are 140hp nozzels they wont actually give me what i need?
Old Apr 16, 2009 | 05:57 AM
94 12valve's Avatar
I would go with the new injectors better pop off pressure
Old Apr 16, 2009 | 10:08 AM
12valvetater's Avatar
what kind of budget are we loooking at here? and personaly i wouuldnt go with the 435s. they have the same spray pattern as the 370s which is wrong for our piston bowls. im going with 8x .009s dont go with nozzels either with the boost in presure the bodies tend to leak.
Old Apr 16, 2009 | 11:20 AM
94 12valve's Avatar
435's have the right spray pattern 145*
Old Apr 16, 2009 | 01:23 PM
rallyit67's Avatar
[QUOTE=12valvetater;324552]what kind of budget are we loooking at here? QUOTE]
I would like to try and find a used set of big injectors but new 435's are pretty cheap iv seen them for about 400. Id like to stay under or near 500 on them.
Old Apr 17, 2009 | 12:25 AM
94cummins12v's Avatar
370's and 435's arnt the same spry pattern the 435 is what is needed for our bowls
Old Apr 17, 2009 | 01:43 AM
89silverbullet's Avatar
well i always had it in my head that there is a marine style 370 with the bad spray pattern and a 370 that has the right spray pattern. new era will tell you they have a correct spray pattern 370. my point is dont get marine injectors. they are cheap but will cost you with how dirty they run.
Old Apr 17, 2009 | 08:37 AM
djwhonda92's Avatar
aww that really isnt good, considering i just installed some 370 marine injectors
