06-07 LBZ Performance Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines Related To Performance And Longevity
front axle tube mount removal?
Old Apr 13, 2009 | 10:37 PM
mikes454's Avatar
Default front axle tube mount removal?
front passenger side axle tube has a beefy aluminum bracket that rubber mounts to the frame in 2 places with long(4")studs, and then bolts to the axle tube to stabilize the pass cv axle...anyone changed this before? to slide the 4" studs on the bracket out of the frame it hits the motor oil pan???i have the gm shop manual and it shows it being changed with no motor in the diagram(obviously because drawing in the motor would block the bracket view)but it doesnt say anything about moving the oil pan or motor or disassembling the stud out of the bracket in order to install it?anyone who's changed this bracket please help!!!
Old Apr 13, 2009 | 11:16 PM
2500HeavyDuty's Avatar
hmm, that big V lookin alumin bracket ur talking about
Old Apr 13, 2009 | 11:40 PM
mikes454's Avatar
yup thats it
Old Apr 13, 2009 | 11:44 PM
Originally Posted by mikes454
yup thats it
ima have to take a look at it tomorrow and see if it can come out ez, never messed with it before
Old Apr 14, 2009 | 12:46 PM
chevyburnout1's Avatar
Just curious why are you taking it out?
Old Apr 14, 2009 | 02:15 PM
mikes454's Avatar
the rubber bushings at the frame mount are shot, i noticed the thing was sitting cocked at an angle to the frame, it looked worn basically, and now that i have all four bolts loose on the thing i can tell its definately shot.maybe i wont spit out cv's every weekend once its tight and supporting the axle tube properly again(doubtful)i guess i'm off to the dealership to ask around there, i'm surprised no one has changed this before,my truck has just over 100,000 k on it and its worn out so go check yours everyone...
Old Apr 14, 2009 | 02:45 PM
Johnny Cetane's Avatar
It's pretty easy but you have to watch for a couple things.
Take out all of the axle shaft bolts and separate that from the stub shaft in the tube.
Remove the 2 nuts holding that rectangular bracket on the end of the axle tube.
Disconnect the electrical connector and pull the loom out of the clip.
Remove the bolts holding the axle tune to the the front diff.
At this point you have to kind of wiggle the tube assembly free from the diff while pulling down on the axle stub side. You might also have to put pressure on the front diff with a pry bar to tilt everything down on the right.
As your pulling the tube watch for parts falling out. Check out the diagram. Parts 12, 13 and I think 9 also can fall out. It's not a big deal. Just pay attention to how the came out and you'll be fine.
Old Apr 14, 2009 | 03:30 PM
GTRW3T's Avatar
those 3 parts will fall out when you pull that axle tube off. if you losen the 2 bolts that hold that alum brakcet into place it will make it easier to pull the axle tube off or like he said just use a pry bar.. its really easy you shouldnt have any problem doin it.
Old Apr 14, 2009 | 10:28 PM
mikes454's Avatar
its not the axle thats the issue its the aluminum v shaped brace that goes where #4 and #10 kinda point at. gm shop manager had no idea so apparently you have to drop the oil pan to remove it, or pull the motor...nice goin gm engineers
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
