Will These Housing Actually Help ?
Old Apr 8, 2009 | 01:31 PM
hereismylife's Avatar
Question Will These Housing Actually Help ?
I have the stock turbo. I am wondering will 1 of these housing actually help? If so which one would you pick first and why? Or is it better to get gust another turbo?
1. I am still stuck on either getting the turbo updated with the housings
2. 4-5 gsk kit
3. rack plug
exhaust side
Dodge 5.9L Cummins 16 sq.cm. Turbo Turbine Exhaust Housing
Compressor side
Stage 3 Power Compressor Upgrade w/60mm Wheel 95-02 Dodge Cummins
Old Apr 8, 2009 | 07:59 PM
oglejust's Avatar
alot of ppl do the comp wheel upgrade to make the 35/40 hybrid, theyre good for i think 500 hp, also the exhaust housing will be a little harder to spool but it will build more boost, its a cheap alternative to an aftermarket turbo
Old Apr 8, 2009 | 08:06 PM
392hemix's Avatar
How much boost would you guys run on a stock head gasket and stock studs?...
Old Apr 8, 2009 | 08:39 PM
stillbad's Avatar
I wouldnt run no more than 40psi of boost, any more an you run the risk of blowing a head gasket. I know people have run more than that an so did i before i had the head work but one to many times an it'll pop (like mine, you learn from experiance) or maybe the first time.
Old Apr 8, 2009 | 08:49 PM
94cummins12v's Avatar
thats the same turbo i have
Old Apr 8, 2009 | 08:57 PM
12valvetater's Avatar
it will be more **** to breaking with those big wheels but should support decent power
Old Apr 9, 2009 | 01:10 AM
what do you have the hybrid turbo?
What running to much boost?
Last edited by hereismylife; Apr 9, 2009 at 01:10 AM. Reason: Automerged Doublepost
Old Apr 9, 2009 | 06:17 AM
Diesel Dummy's Avatar
the compressor upgrade is well worth it, the 16 is going to be real laggy with an auto, i would suggest not going any bigger than a 14 cm housing. (94cummins12V) ended up with my hybrid i built just ask him how it is working out for him.
DD
Old Apr 9, 2009 | 10:23 AM
i love that turbo it sounds relly nice and supports the power i need, for towing and daily driving, its a little lagy but not to bad with the 5 speed
Old Apr 9, 2009 | 02:47 PM
kazairl's Avatar
FYI the 35/40 hybrid won't support 500 HP more like 400 maybe 450.
