Which DPF delete company?
Old Apr 7, 2009 | 11:41 PM
FarmDiesel's Avatar
Default Which DPF delete company?
I have a friend that recently purchased a 6.7 and is interested in a delete, I went with the BADP "Code free" dpf delete kit. Of course what I got out of that was 3 exhaust codes and occasional white smoke What would be a better company to go with?
Old Apr 8, 2009 | 08:47 AM
DslDeamon's Avatar
i have a H & S 5 inch turbo back and so far ive had no problems with it and with a programmer is pretty much code free you can give them a look see their web site is Rollin' Smoke Diesel - Diesel Perfomance Parts good luck
Old Apr 8, 2009 | 09:08 AM
94Matt's Avatar
H & S has a code free programmer out now, and the smarty is supposed to ship on the 15th I believe, it will be code free as well.
Old Apr 8, 2009 | 11:38 AM
cdiesel217's Avatar
i have dpf-r 4in delete and i have never seen a code
Old Apr 8, 2009 | 01:09 PM
need help 6.7's Avatar
get pro- flo kit and a smarty and also delete the egr it will be completely code free with the smarty
Old Apr 16, 2009 | 10:58 PM
Rollin Smoke Diesel's Avatar
FormerVendor
Codes and a CEL are inevitable when doing deletes. The best bet right along when deleting the DPF is to go with the XRT or Smarty to be code and light free.
James
RSD
Old Apr 17, 2009 | 12:28 PM
I would have to agree with James. XRT or Smarty. XRT with Sims and an Expandit 5" makes a nice combo.
Luke
Old Feb 4, 2010 | 02:29 PM
Flogster's Avatar
Default What DPF Delete
From what I have seen, it depends on what you want. If your after a kit that don't modify the ECU and thus wont mess with your warranty "wont be a tune no extra power and what not" simply a dpf/egr removal and that is all you want the dpf-r made by gearboxz.
however if modifying the ECU and risking your warranty is not a issue and it probably isnt the H&S or smarty would probably work fine.
Old Feb 4, 2010 | 02:53 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
smarty , xrt and black max.
Old Feb 8, 2010 | 11:55 AM
puller451's Avatar
I have purchased a Smarty 67S with the delete software in it, ordered an H&S EGR and cooler delete, and bought a dpf delete pipe. Once this is all installed do you still have to change your oil every 5000 miles, or since all the smog crap is gone that makes your oil dirty can you go longer?
Thanks,
first time poster,
been reading on here for a while!
