94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
tw chip check engine
Old Mar 27, 2009 | 12:48 PM
teerin2deep's Avatar
Default tw chip check engine
I just installed installed TW 5 pos chip, chip is awesome only problem Im having is when I switch to extreme mode check engine light comes on truck cuts off. My truck is a 95 f250 5spd, Tymar Intake,3"dp 4" straight pipe,FPR shim,pyro and boost guage,164,xxx. And thanks in advance love the site, you all are powerstoke guru's and have made all my mods from yalls advice.
Old Mar 27, 2009 | 04:31 PM
Give TW a call Ive never had this issue with my TS Chips.
Luke
Old Mar 29, 2009 | 10:51 PM
robammerman's Avatar
I get the same problem on mine if I really get into it. I comes back with a code saying my IPC pressure is above/below desired.
Old Apr 1, 2009 | 01:59 PM
slowtowpig's Avatar
Could be a code for low high pressure oil pump
Old Apr 22, 2009 | 02:13 PM
IHWelk49's Avatar
x2 on the low pressure from the HPOP.
Old Apr 27, 2009 | 11:16 AM
PSD0389's Avatar
Yep Id say thats your HPOP not being able to keep up, its not uncommon
Old Jan 15, 2010 | 07:37 PM
dieseldan73's Avatar
all that means is that the computer is sensing higher then acceptable pressure levels so its cutting the truck off. there isnt really a way to stop this i'v tried
burndiesel
10
Feb 7, 2023 01:15 AM
Higgy
Jun 5, 2015 09:16 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
Rebel_redneck
Sep 29, 2014 11:05 AM
