Need Help
Old Jun 2, 2007 | 11:09 PM
DazedandConfused's Avatar
Default Need Help
Ok I just converted my 2001 Dually from an auto to a manual and I'm having a problem. When I start it up and take off it will run to 2000 RPM's and that is it. I checked codes and the only one I can see causing this would be the 0720 Low Output SPD Sensor RPM, Above 15 MPH My question, is there a output speed sensor on a 94 NV4500 and how would I wire it from my 2001 47re to work. Sometimes I can get past it and it runs fine but most times it is a pain. It will only do this until it passes this point and will not do it again until I shut the truck off. Someone please help me."give:
Andy
Old Jun 2, 2007 | 11:55 PM
Uncle Bubba's Avatar
Here's another thread that talks about thexact same problem code as your gettin and the conversion. Hopefully it helps out. He got his working right.
http://www.idahobombersforum.com/vb/...read.php?t=789
Old Jun 3, 2007 | 10:14 AM
Thank you for the link.
Andy
Old Jun 4, 2007 | 05:15 PM
Got some good news, Bob Wagner told me to send it to him and he can reprogram it without a problem.
Andy
Old Jun 11, 2007 | 02:49 PM
Ok I got it fixed, still need to figure out if I can get the cruise working or not but if I dont then its not that big of a deal.
