KW w900 Cummins BC 400 black smoking no power HELP!!
Old Mar 23, 2009 | 05:18 PM
born2wrench's Avatar
Default KW w900 Cummins BC 400 black smoking no power HELP!!
The truck is a 1985 W900 with a big cam 400 Cummins. I'm planning on buying the truck but I need help. The owner was hauling a load when he lost power. It would still run but with major black smoke. I was told it probably melted a piston, can't hardly believe that when it was a sudden event. I've been thinking and told that it is probably a bad turbo.
Anyone have any input on this?
Old Mar 23, 2009 | 06:03 PM
MotorOilMcCall's Avatar
Turbo, intercooler, piping, boot... Plastic bag sucked into the air cleaner, etc. Its something to do with the intake of air. He's probably right, the turbo is likely shot... Question is why. High EGT's can kill a turbo, and wreck a lot of parts as well. Just keep an eye open on anything else that looks out of place.
Old Mar 23, 2009 | 09:50 PM
vlado's Avatar
most likely one of the intercooler rubber boots got hole in it,if it's all of suden and assuming that turbo is good.also check for exaust side if turbo i have seen a lot of shafts broken in the back and wouldnt leak oil as usualy does when turbo goes bad.Good luck
Old Mar 23, 2009 | 09:53 PM
Whit's Avatar
Site Mascot
they are right.........its lack of air
pull the inlet filter and see if the pinwheel is free to spin, wiggle it to check for bearing slop............check the boots real good specially the first one after the charger
Old Mar 24, 2009 | 12:39 PM
dieselmadscientist's Avatar
also think air filter or turbo is the problem
Old Mar 24, 2009 | 09:02 PM
Thanks for the input guys. Hadn't thought about the intercooler plumbing. Will check all of the above when I have a chance( I live 2 1/2 hours from where the truck is being stored).
So pretty much if I figure out where I'm losing my boost(air intake) the engine itself shouldn't need an in frame over haul, right??
Anyone know anything about hot rodding these old Big Cam Cummins motors???
Anyone have any suggestions on how to get ahold of some second hand truck batteries?
Two of mine are dead, just need two more real quick to get it up and going to finish diagnosing.
Thanks,
Shawn
Old Mar 25, 2009 | 06:50 PM
The engine itself should be fine, and yes, you can really crank up those old big cam motors. No idea on the batteries...
Old Mar 26, 2009 | 11:58 AM
03maxpower's Avatar
put an n-14 turbo on it they spool quick and flow alot of air and bolt right up
Old Mar 26, 2009 | 04:28 PM
And choke out the top end...
Old Mar 28, 2009 | 09:42 AM
wildbill's Avatar
Any updates??
