gettin to the fuel plate
Old Mar 20, 2009 | 11:07 AM
Rocky Mountain Texan's Avatar
Default gettin to the fuel plate
how did ya'll get that one screw off on the corner of the afc housing? Did you chisel it off or what? I can't get it off to get to my fuel plate.
Old Mar 20, 2009 | 11:10 AM
94 12valve's Avatar
https://www.dieselbombers.com/12-val...-off-bolt.html
Old Mar 20, 2009 | 12:11 PM
djwhonda92's Avatar
ya all i keep hearing is that you need to chisel it off.
Old Mar 20, 2009 | 01:04 PM
94 12valve's Avatar
I sloted mine and unscrewed it but to each there own
Old Mar 20, 2009 | 03:57 PM
sstockton's Avatar
I use a t12-15 torx head driver, tap it in with a dead blow and then twist it out. its always worked quite well for me. Slotting it works also. The driver just seems to be a real snap.
As far as chiseling, are you thinking of trying to snap the head off with a chisel or using a chisel to slot it?
Sean
Old Mar 20, 2009 | 04:49 PM
Cummins97's Avatar
Same here. Then I replaced all of the bolts with new ones from the parts store so they're all nut heads.
Old Mar 20, 2009 | 06:14 PM
98_12Vcummer's Avatar
i was able to get the chissel in there, actually from the side, with the corner of the chissel, dug it in and got it loose. i turned it with every wack or tap of the hammer. then chisseled a notch for a flat tip
Old Mar 20, 2009 | 10:15 PM
94cummins12v's Avatar
i actulay used a drill to take the head off mine believe it or not
Old Mar 22, 2009 | 01:05 PM
ykdave's Avatar
i tried to chisel a notch into mine to unscrew it but the head just popped off!
No big deal though, just uncrewed what was left of it once the housing was off and out of the way...
Old Mar 24, 2009 | 08:47 AM
djwhonda92's Avatar
ya idk why, my afc housing had four bolts and all of them came out
