Hankook ATM RF10
Old Mar 19, 2009 | 11:27 PM
ScrmnEagle's Avatar
Default Hankook ATM RF10
There seems to be a lot of traffic on this and other forums about tire options for our trucks. With that being said....
After reading this information and others recommendations the past several months I decided to take the plunge and pursue the purchase of some new shoes. Had been running the Toyo's AT 285/75/17 (sipped). With 28K+ miles and 9/32 of 17/32 remaining, they were wearing nicely, until just recently when it was noticed a lot of slipping on wet pavement, corners etc... Always properly inflated I had been experimenting with different tire pressure (unloaded) to correct this issue. No improvement. I knew it was time for a change.
So.....my search was narrowed to the Hankook ATM RF10, Nitto Durra/Terra Grappler, and BFG (always a popular choice). We all know that a lot goes into others recommendations considering we all drive differently and have different uses for our Duramax's. One of the deciding factors for me was a 4X4 Tire review conducted by a third party - the National Forest Association. The link is http://www.4x4tirereview.com/ATcomparotest.html.
Well, with a 60K warranty and the above information I bit the bullet. Got a great deal, mounted, balanced, siped, and filled with nitrogen for <$750, with a small trade. Here are some pics and a copy of the warranty.
I will chime in later to let everyone know how they perform and wearing.
Attached Thumbnails Hankook ATM RF10-hankook-warranty.jpg   Hankook ATM RF10-img_0002.jpg   Hankook ATM RF10-img_0003.jpg   Hankook ATM RF10-img_0004.jpg
Old Mar 20, 2009 | 01:48 AM
94cummins12v's Avatar
im not a fan of the hankooks i have the dynapro mts in a 285/75/16 and they suck in the snow and mud, there ok for pavemnet
Old Mar 20, 2009 | 07:52 AM
Buckshotmckee's Avatar
Sma't Alec!
I looked @ the hankooks but ended up putting the new yokohama a/ts on. So far so good. I bought them @ discount as well. They gave me a pretty good deal, $640.00 out the door with a 50k warranty.
Old Mar 20, 2009 | 08:32 AM
DIESELDENT's Avatar
Thoes hankooks have gone up alot i paid $152ea back in november from the same place. They have decent traction and look god but has any one have a problem with balancing, i had to take mine back in to get rebalanced right after they put them on and there still not great the shop said they were slightly out of round.
Old Mar 20, 2009 | 07:30 PM
ScrmnEagle's Avatar
COuld have been a bad batch. When I purchased a set of Toyo MT's LS went thru 10 tires before the found a set of 4 round tires. Subsequently they only lasted 2 weeks. Had them removed and my original tire put back on, Les Schwab could not get the set to balance. Guess you never know until you try them. Thankfully, most franchised tire shops have a 30 trial period.
Old Mar 20, 2009 | 10:49 PM
trashygasman's Avatar
I had a problem getting mine balanced at first. I kept throwing weights. After the third time, I haven't had anymore problems. I have about 25k on mine.
Old Mar 20, 2009 | 11:40 PM
If you used Balancing Beads you wouldnt have had that problem:
Tire Balancing Products
Counteract Balancing Beads
Old Mar 22, 2009 | 02:31 PM
I havent ever heard of using them in light trucks. I thought they were only used in big rigs.
Old Mar 22, 2009 | 03:09 PM
mikmaze's Avatar
I was thinking of these as well, debating between these at's or the mt's...... at's most likely wear better, and at 800 bux a set, thats important.
Old Mar 22, 2009 | 04:04 PM
cummins freak's Avatar
i've been looking at these in 315 70 17 I'm glad to see someone is trying them out for me HAHAHAHA
