94-98 12V Cummins 5.9L P7100 Tech Talk '94-'98 5.9L Cummins 12-Valve P-9100 Tech Articles
2nd Gen Rear Wheel Cylinder Upgrade
Old May 31, 2007 | 09:12 PM
Whit's Avatar
Site Mascot
Default 2nd Gen Rear Wheel Cylinder Upgrade
This is for changing out your rear brake cylinders from a ¾ ton to 1 ton cylinders. First thing you need to do is go to your local auto parts store and ask them for GM part #4637337. DO NOT tell them you want GM 1 ton cylinders for your a ¾ ton Dodge. You will only confuse them. They sometimes will tell you that they have a cheaper cylinder or a higher quality one. I chose the higher quality one and paid around $80.00 for the pair, but they do come with a lifetime warranty. Might as well grab a couple cans for brake cleaner while your there at it because youll need it.
Go home, block the front tires and jack the rear of the truck up. Place jack stands under the axle and remove both tires. Next you will need to remove the brake drums. They usually dont come right off. What I did was take 2 lug nuts and spun them back on the studs on each side. I started the truck, put it in reverse, got the rpm up and hit the brakes hard. One drum broke loose, but the other didnt. I had to take a heavy punch between the studs and strike it with a large hammer. It broke loose finally.
Your drums will probably not slide right off. Back off the adjusters a tad and it should slide off. Spray the parts down with brake cleaner and get things cleaned off. Now is a good time to look at your brake shoes while you have the drum off too.
You will need to remove ONE spring from the shoes to allow it to spread apart so you can get the cylinder out. (See Illustration) It is only necessary to remove the forward spring (the RED one in the pic below), meaning the one facing the front of the truck. This will free up the shoe so you can remove the cylinder.
Take a 3/8 wrench and remove the brake line from the back of the cylinder. Take a 13mm wrench and remove the two bolts securing the cylinder to the housing. Remove the cylinder.
The 1 ton cylinder is noticeably larger.
You will need to reuse the metal pieces that spread the shoes. (You will see when you do it). Put the new cylinder in, tighten the bolts and install the brake line back in. Also secure any springs that you removed. Put the drum back on and adjust the brake adjusters until the just barely drag on the drum. Start the truck and bleed the air out of the system. Put your wheels back on and you’re ready to go.
I had been battling hard pedal for almost 2 years and figured it was in my master cylinder/booster. After doing this my brake pedal is soft and I have awesome brakes now.
Old May 31, 2007 | 09:33 PM
MRaynor's Avatar
Keep in mind guys that this will not work on 05 at least . I know mine has no drums, and I am not sure when this was started.
Does sound like a hell of a fix if you have them though.
Old May 31, 2007 | 09:38 PM
DB Admin's Avatar
Banned
2002 Was the first year for disk brakes
Old Jun 1, 2007 | 03:51 PM
DBogo's Avatar
so how much better are the brakes after the upgrade?
Old Jan 18, 2008 | 09:57 AM
Whit's Avatar
Site Mascot
I would say an aprox 30% gain in braking power
Old Jan 18, 2008 | 11:25 AM
Not correct - 2001.5 was when disk brakes first appeared.
Old Jan 18, 2008 | 11:27 AM
Whit's Avatar
Site Mascot
yeppers.........01.5 was the first disc brakes on the rear
Old Jan 18, 2008 | 02:22 PM
Uncle Bubba's Avatar
This made a night and day difference in my trucks brakes. I just did it here a few weeks ago.
Old Jan 18, 2008 | 04:07 PM
Lil Dog's Avatar
I will have to do that upgrade in the warmer weather. Need to flush the system anyway..
Old Feb 10, 2009 | 02:03 PM
Grider Pirate's Avatar
Default Brake cylinders AND shoes
Oops, just noticed this is a pretty old thread. Hope nobody minds the resurrection!
Anybody have any recommendations for brake SHOES? I'll be installing the GM wheel cylinders in my (wife's) '99 this weekend, and I suspect I'm going to need to replace the shoes while I'm in there.
Thx
