EFI Live... need Help
Old Feb 28, 2009 | 02:17 AM
dhardy1357's Avatar
Default EFI Live... need Help
ok. so my efi just came in and i cant even figure out how to install the software.i have the installation cd but nothing even pops up on my comp when i put it in.im goin to walmart tomorow mornin to buy another computer to see if that works. but if anybody has any advice /ideas... it would would be much appreciated--thanks,Dustin
Old Feb 28, 2009 | 08:29 AM
redneckbuckeye's Avatar
Where are you located?
Old Feb 28, 2009 | 08:38 AM
stkdram55's Avatar
Danny calling Danny
Old Feb 28, 2009 | 11:50 AM
uwyo_dmax's Avatar
Try downloading the latest release of the EFILive site. Downloads Download the first two files on that page, if that works I think you will have to download the USB driver also. I'll check more into that and let you know.
Old Feb 28, 2009 | 01:28 PM
2500HeavyDuty's Avatar
when you download the latest versions of efi live, there is a word document that is downloaded with it too, its in the start menu under the efi live > v7
it should tell you how to set up the controller and update the firmware and bootblocker.
and in the tuning program go to help and register efilive and enter the serial number, ther v2 version you have would be the commercial scan and tune
Old Feb 28, 2009 | 01:32 PM
efi live have a forum on thier website also. you can get direct awsners about the sofware and updates on thier website from the guys who created efi live.
EFILive Forum - Powered by vBulletin
Old Feb 28, 2009 | 07:03 PM
dhardy1357's Avatar
ok. so i think the problem was my computer. i went out and just bought another one. i got it all installed and i played with the scanner a lil bit. but now im kinda clueless on what to do.
i am in houma louisiana
Last edited by dhardy1357; Feb 28, 2009 at 07:03 PM. Reason: Automerged Doublepost
Old Feb 28, 2009 | 07:22 PM
did you read that word doccument that came in the file when u downloaded the efi v7?
what versions of firmware and bootblock do you have on the v2?
your v2, efi live v7.5 and v8.1 are most likely out of date since you just got your stuff.
that word doccument that is installed under start>efilive>v7.5> and there should be a work doccument there, im not at home so i cant tell u exactly. but it should tell hour exatly how to update your v2 and programs.
also:
After Installing:
When the installation has finished, EFILive will check for updates. If EFILive does not automatically check for an update after the initial installation, please select the start menu option: Start->All Programs->EFILive->V7.5->Tools->Check for New Update.
Most likely an update will be available and should be installed to ensure you have the most up to date software. The update usually takes 1-2 minutes and will display a message to indicate when it has completed.
i can help out in more detail when i get back home monday mornin.
Old Feb 28, 2009 | 07:23 PM
Also on the efi website they have turotials and some doccumentation on there under the downloads section
Downloads
just scroll down a bit
Old Mar 1, 2009 | 01:50 PM
dhardy1357's Avatar
ok thanks guys. im now tryin to figure out how to load a custom tune. i downloaded one from the internet.i have read my ecm and saved it to a disk. now what do i need to change on the tune i downloaded to make it work for my truck.iv read something about tire size and os need to match my truck. anyone know?
