DD install problems
Old Feb 28, 2009 | 12:49 AM
Cummins97's Avatar
Question DD install problems
I installed my new DD today. When I went to start it, it just clicked really loud. For some reason I thought to try and turn the harmonic to see if it would turn. No dice the motor is now locked tight. I took out the starter thinkin maybe it hung up somehow. Still locked with no starter. Transmission turns when in neutral. Motor turned before installing transmission, I had to hold it to torque the pressure plate. We're thinkin something in the clutch, input area.
Any other ideas?
Old Feb 28, 2009 | 08:37 AM
stkdram55's Avatar
it wont do anything?? With the tranny in neutral it still wont turn by hand?? If so what the hell did you do!!! JK.
is the neutral safety switch working? That would have nothing to do with the engine not turning but IDK
Old Feb 28, 2009 | 10:00 AM
Cummins97's Avatar
Nope it wont do nothin. Tranny in neutral, clutch pressed in still nothin.
I guess I'm gonna go tear it back apart and see what I find.
Will post back if I find it.
Old Feb 28, 2009 | 03:13 PM
Beets's Avatar
Is your neutral safety switch hoked up?
Old Feb 28, 2009 | 04:54 PM
kazairl's Avatar
You did install the starter spacer correct?
Old Feb 28, 2009 | 05:43 PM
Cummins97's Avatar
I found it.
Wrong clutch, we're guessing. The pressure plate is hitting the bell-housing.
Gotta call GOS and see what Aden says on Monday.
Old Feb 28, 2009 | 06:26 PM
stkdram55's Avatar
you dont have the plate in backward due ya??
Old Feb 28, 2009 | 06:34 PM
Cummins97's Avatar
No. Everything is put in exactly as it came apart.
Old Feb 28, 2009 | 06:36 PM
stkdram55's Avatar
k just checking my friend had issues with his clutch he had one of the discs flipped around, but he could atleast start the truck
Old Feb 28, 2009 | 06:52 PM
Whos clutch and whats the part#?
