03-07 Cummins CR 24V 5.9L Tech Talk Tech articles for the 03-07 Cummins Common Rail 5.9L Engines.
03-05 fuel can mod instructions
Old Feb 24, 2009 | 07:03 PM
cbrahs's Avatar
Default 03-05 fuel can mod instructions
Ok here are some instructions on the fuel can mod for the 03-05 Dodge truck when installing an Airdog or FASS fuel system and 1/2" lines.
Step 1. REMOVE YOUR FUEL CAN
Step 2. Mark your fuel can by scribing it so when you reassemble, it goes back together in the correct clock position.
Step 3. Take a pair of needle nose pliers and reach into the can, grab a hold of the black tubing that goes to the bottom and pull up. This dislodges the stock pick up tube and will also allow you to separate the can in half. NOTE: 1 of the tubes is just a vent (black rubber cap on the top of the can) pull on the other one!
Step 4. Reach inside the can and unplug the sending unit before splitting in half. Don't want to do any wiring damage! There are 3 lock tabs on the canister (black arrow in pic). These are a pain in the rear but once done, the can splits in half.
Step 5. There is a pre-filter on the bottom of the can. There are also 3 lock tabs to remove. Remove this pre filter now.
step 6. Since I have done a couple of these, I cut the black tubing. Here is a shot inside the fuel can (under side of the top)
step 7. remove all the black tubing that came on the can stock. Turn the can upside down and you will see 2 holes (1 has a nipple). The one with the nipple, you will drill thru to 3/4" to enlarge the pick up surface area.
after drilling
step 8. Attach the billet pick up to your hose
step 9. don't forget to re-install the lock ring removed from the stock pickup. this locks the aluminum pick up in place
step 10. reach inside the lower section of the can and install the pick up into the stock location. re-install lock ring
step 11. Now for the top half. Drill 2 3/4" holes to insert your bulkhead fittings (must buy them from a local source or I can provide additionally)
Old Feb 24, 2009 | 07:07 PM
ETXBlueRam's Avatar
Nice.
Old Feb 24, 2009 | 07:17 PM
cbrahs's Avatar
step 12. Slide the 1/2" line onto the barbed fitting and test the can out by sliding it down and look for binding of the new hose. once no binding is confirmed, secure with a cable tie to ensure it does not come off the barbed fitting
step 13. Reassemble the fuel canister. Make sure you line up your marks before you snap it into place!
step 14. The prefilter has 2 layers of filtration. I removed the top half (it has 2 small valves see the prefilter on the right). after you remove that section reinstall onto the canister.
Now you are ready to install the can back into your truck!
These pickups are going to be $45 shipped. We will release them soon. We are currently testing in 2 trucks. One of which is a bad *** with twins and a crap load of mods.
Old Feb 26, 2009 | 01:48 PM
cbrahs's Avatar
Default Update
Well having OCD when it comes to this stuff aint all that bad. After some bench testing, It was not pulling the fuel down as far as I would like so we went back to the drawing board, made some minor changes and after testing it is DONE!
in step 14. you will have to remove the top layer of screen.
in step 7. you will have to drill the nipple off to enlarge the hole to 3/4" and a uni bit does great! This will allow the new pick up to reach farther than the stock one did!
Here are a couple pics of the updated version. New one on the left.
here is a pic of the unit protruding past the bottom. This will allow it to get damn near to the bottom of the tank and retain a pre filter!
It was tough to get a good shot but this pic you can see the pick up reaching deep into the bottom near the pre filter
With the changes, the price unfortunately had to be increased to $55 shipped. If you are wanting the hose alone with the kit, it is $65 shipped.
Old Feb 26, 2009 | 11:48 PM
cummins tech's Avatar
Sweet but to bad i have an 06 Ram
Old Feb 27, 2009 | 08:44 AM
cbrahs's Avatar
we have the fix for those too
Old May 14, 2009 | 03:32 PM
Red_Rattler's Avatar
High Tech Redneck
Chris, So this is the basket outa an 03 truck? Just tryin to figure out what I'm goin to do if this is one outa and 03 since the directions show a totally different style basket with the new style pickup AirDog has......
Old May 15, 2009 | 08:23 AM
cbrahs's Avatar
all of the 3rd gen pre-in tank pump canisters look like the one airdog is showing due to the lift pump being installed at the bottom of the can. For those who have had the retro performed, you will need the pick up for 06 adn newer.
Old Dec 17, 2010 | 10:44 AM
Boosted Cowboy's Avatar
My fuel cage looks just like this one. So I don't need to drill holes in the sides for the fuel to keep up, or do I? My truck is an 02. I need to gut the section with the fuel sending unit on the outside of the fuel can?
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
