low, lopey idle
Old May 26, 2007 | 04:25 PM
DBogo's Avatar
Default low, lopey idle
alright my truck starts and runs great, although after i drive it for a while it will idle slightly low, right below the line, im not sure what the line is maybe 750 rpms im not sure but if you got a 94-97 you know the line anyways when i start it it will run right there smooth as silk after i drive it for a while the idle will drop just below that line and if you give it throttle to bump it back up to that line it is real shakey and lopey all the way up till about 1200 rpms, im not sure at all whats causeing this but im getting sick of it, maybe some of you guys can help me out here, thanks
Old May 27, 2007 | 11:12 PM
DBogo's Avatar
anyone??
Old May 28, 2007 | 12:15 AM
Benjamin's Avatar
Bombardier
try bumping the idle up a little bit and see if that is the problem....
Old May 28, 2007 | 06:56 AM
DBogo's Avatar
sometimes it idles great though but once its warmed up and ive been running it for a while it does the thing with the low idle and lopes and shakes
Old May 28, 2007 | 09:46 PM
Benjamin's Avatar
Bombardier
mine did that.... i idle mine at 1000 in park or 800 in gear with the a/c on.... check that and see what happens....
Old Jun 8, 2007 | 05:24 PM
DBogo's Avatar
that seems really high, this is driving me nuts its great till you been driving it a while and i dont know whats causeing it
Old Jun 12, 2007 | 10:20 AM
Monster Truck's Avatar
Id adjust the Idle when the engine is hot, then it should idle alittle high when cold which is good.
Old Jun 15, 2007 | 04:29 PM
DBogo's Avatar
alright maybe this will help heres a outside video and an inside video of what it sounds like, this is after driving about 30 miles home from the fire cheif convention on highway and about 5 miles around town, i also jacked the idle up and it was idling above the 750 line and now its back there after driving this distance
it almost sounds like it has a miss below 1250 rpm's above that its smooth as silk
and btw the exhaust dosnt touch the bed its about a 1/4" away, thats the only way i could snake the 5" through there
[GVIDEO]http://video.google.com/videoplay?docid=-7809185787916028428 [/GVIDEO]
[GVIDEO]http://video.google.com/videoplay?docid=-8492969664429062835[/GVIDEO]
Old Jun 27, 2007 | 11:26 PM
Cummins Express's Avatar
overflow valve possibly
AutoMerged DoublePost
have you eliminated the overflow valve as a variable?
Last edited by Cummins Express; Jun 27, 2007 at 11:26 PM. Reason: Automerged Doublepost
Old Jun 29, 2007 | 05:58 AM
DBogo's Avatar
i have not, i beleive mine is not the origional because its a 95 and it has the nut on top, does that sound like the symptoms of a bad overflow valve
