OIL LEAKING BAD
Old Feb 21, 2009 | 10:08 PM
biged681985's Avatar
Default OIL LEAKING BAD
i was driving driving in circles and after i got done my truck was leaking oil out of it real bad. its leaking right arund the computer, on the drivers side block. im gonna try to tear it down to figure exactly where its leaking from, but i believe its from the pushrod cover on the side of the block. an other ideas where it might be coming from.
Old Feb 21, 2009 | 10:10 PM
94cummins12v's Avatar
head? or lifter cover. that cover is a pain in the *** to remove with the fuel pumps on there, $20 gasket is all it is
Old Feb 21, 2009 | 11:19 PM
Cummins97's Avatar
Sounds like the lifter cover.
Or maybe the oil line for the power steering/vac pump?
Old Feb 22, 2009 | 01:11 AM
the vaccum pump is down low toard the timin case and the powersteering pump is oiled by th evaccum pump if its toard the rear i doubt it would be that i know them tappet cover seals go bad often if it gets to hot
Old Feb 22, 2009 | 02:42 AM
xzaq103's Avatar
FormerVendor
All I know is its A LOT of oil.
Good luck ED call me if you need any help.
Old Feb 22, 2009 | 09:58 PM
the gasket on the lifters, pushrods is sticking out the bottom of the cover, so im positive thats whats leaking
Old Feb 22, 2009 | 10:01 PM
Dang Ed you were raising some hell
Old Feb 22, 2009 | 11:00 PM
xzaq103's Avatar
FormerVendor
EDs alwyas doing that. Take a look at the video section.
Old Feb 24, 2009 | 10:13 PM
wildbill's Avatar
Any updates??
Old Feb 24, 2009 | 11:25 PM
got her back up and running this afternoon. had to go back and fix a small fuel leak but got it fixed. gonna put the smarty back on it tommorow.
