Sprays 'oil?' at startup
Old Feb 5, 2009 | 06:11 PM
vepr308's Avatar
Default Sprays 'oil?' at startup
I have a '99 F-250 powerstroke 7.3L with 'bout 230,000 miles on it
Often when i start it up (60-70% of the time) it spews fluid (looks like oil) from the right side of the engine compartment. Not sure exactly where from... just see it when I pull away.
My engine oil level doesn't seem to be going down... I've lost enough fluid that i should notice a difference.
This is my first diesel and I don't know much about them. i would appreciate any ideas.
Old Feb 6, 2009 | 05:38 AM
gunman41mag's Avatar
Moderator
HI vepr308, Are you sure it's OIL??? Cause my 1999 F-250 leaked in the same area, and it was the valve attached to the water/fuel seperator it was leaking diesel. FORD charged me $44 for the part !!!
Old Feb 6, 2009 | 06:27 AM
wildbill's Avatar
Maybe catch a sample and see if it has any sort of odor to it.
Old Feb 6, 2009 | 02:26 PM
vepr308's Avatar
Not sure if it's oil... I'll try to catch some to find out for sure...
The couple of times I've looked for it, there was no leak...
Ok, I got a whiff of it... definately diesel.
I see a puddle of fuel behind/under the filter/separater/valve.
How hard is it to change that valve? How can I be sure that it IS the valve?
Old Feb 7, 2009 | 02:41 AM
Moderator
If there is a puddle it's the valve, it will cost you $44 at the FORD deal, It's not hard to change, you will need an allen, don't remember which size
Old Feb 7, 2009 | 05:16 PM
sirthomas's Avatar
https://www.dieselbombers.com/ford-p...ve-repair.html
Old Mar 2, 2009 | 05:09 PM
vepr308's Avatar
Default Thank you Thank you
ok.. replaced that expensive and cheaply made little valve, no more leak... For now!
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
jhprice
Mar 29, 2015 09:36 PM
coors_man_2005
Dec 15, 2014 10:23 AM
