Delivery Valves
Old Feb 5, 2009 | 06:10 PM
nhart713's Avatar
Default Delivery Valves
OK guys i'm on a tight budget. i have a baby on the way. My job consist on towing medium to heavy loads. I'm wanting more power to tow. I want injectors but dv's are cheaper. what should i go with. or any suggestions on what to get. you can read my sig what i have done already.
Old Feb 5, 2009 | 07:09 PM
xzaq103's Avatar
FormerVendor
I would go with some mild injectors instead of DVs If you do go with DVs just pick up some 181s out of a 96-98 5 speed or auto truck. BUt your not going to make much more HP with just the DVs
Old Feb 5, 2009 | 08:36 PM
94cummins12v's Avatar
dont buy dvs if you dont have injectors or pump mods/ timing first
or a turbo just dvs will creat alot of heat fast
Last edited by 94cummins12v; Feb 5, 2009 at 08:36 PM. Reason: Automerged Doublepost
Old Feb 5, 2009 | 11:02 PM
oglejust's Avatar
your sig says:
95 Dodge ram 2500 12 valve, #0 fuel plate, custom air intake, 4 in turbo back straight, star wheel turn in half way, fuel pump with a 1/2 of a turn. manual trans swap
wth fuel pump w/ 1/2 a turn...
Old Feb 6, 2009 | 12:41 AM
timing is the only thing i can think of it might be
Old Feb 6, 2009 | 07:08 AM
nhart713's Avatar
ok so if i was going to get injectors what a good price injector.
Old Feb 6, 2009 | 11:17 AM
94 12valve's Avatar
you should mod your afc its free, find a set of 181 dv's, get a set of 215 injectors, and a 3k gsk
Old Feb 6, 2009 | 11:38 AM
sstockton's Avatar
I agree with 94 12v. Just pick up some 215 injectors, they are capable of supporting decent numbers. 181's would be a fine DV but there are other free/cheap mods that can be done instead. I'm sure you can find a set of used 215's for around $100. Then I'd tune your AFC, add a 2095 rack plug, and set your timing. This will allow you to still control your EGT's quite effectively as needed, but also give you some extra power as well.
Sean
Old Feb 6, 2009 | 05:43 PM
oglejust's Avatar
Sean
id love to find 215's for 100 bux.... as well as some 181 dvs
Old Feb 6, 2009 | 07:00 PM
nhart713's Avatar
this is a stupid question prolly but where is a good place to get the 215 injectors.
