99 stroker want hit a lick
Old Feb 3, 2009 | 10:04 PM
dustin2282's Avatar
Default 99 stroker want hit a lick
i have 99 stroker and it will turn over and spin really fast batteries are good hpop is full of oil new cps. scanner said exaust back pressure malfunction. any ideas out thier thanks
Old Feb 3, 2009 | 10:09 PM
Benjamin's Avatar
Bombardier
how many miles does it have on it?
while you are cranking does the oil pressure gauge in the cluster move up?
do you have good fuel pressure?
when was the last filter change?
when was the last time it was running?
did this happen all of a sudden?
have you done anything different that could have caused this like put a programmer on it or remove one?
Old Feb 4, 2009 | 07:09 PM
dustin2282's Avatar
well it always had ran fine up till a couple weeks ago it was real cold it wouldnt start so i put new glow plugs in and ran fine for about 30 minutes then service eng came on went to missing the it just quit and that was it the electric fuel pump is working ful filter is fine and i did have an evolution after it died i took it off but didnt make any difference it has 220k.but i had it all apart 10k ago everythinglooked well i did a head job with new valves. thanks yes iol guage does come up
also i get a code says pcm failure [kam] keep alive memory error.
gunman41mag
The Sportsmen's Lounge
Sep 6, 2015 02:29 PM
Jun 29, 2015 11:50 AM
CUMMINONYOU89
For Sale
Feb 4, 2015 09:18 PM
Nov 5, 2014 07:00 PM
