water meth
Old Feb 2, 2009 | 11:29 PM
94cummins12v's Avatar
Default water meth
would this be an ok kit for the moeny?
eBay Motors: WATER METH IINJECTION TURBO TURBOCHARGER IINTERCOOLER (item 110314775821 end time Feb-17-09 11:22:56 PST)
Old Feb 3, 2009 | 01:20 AM
jnicewan's Avatar
you could probably make this work decent, but it looks like it intended for WOT drag racing setup. it injects a constant amount of fluid and is triggered at a desired boost pressure. i would think for this one you may want set it to come on between 20-25psi. maybe higher if you can cheat the pressure switch.
Old Feb 3, 2009 | 01:24 AM
i was thinking 20 for towing
Old Feb 3, 2009 | 01:46 AM
jnicewan's Avatar
it would be trial and error but since it only injects a calibrated amount you might find that you need to up the adjustment so it doesnt over do it at the lower boost. this kit is worth checking out i ould maybe like to call and talk to them about it. plus they said they will have to set the nozzle to customer specs.
Old Jun 22, 2011 | 04:38 AM
TheCumminskid's Avatar
Cheap water meth set up would be...get a windshield washer tank and motor wire to a push button switch and use rainX. Iv had acouple diesel techs tell me about this, don't know if it'll work but I was gonna try it.
Old Jun 22, 2011 | 09:07 AM
odnob's Avatar
I am a bit new at all this; what is a "water meth"?
Old Jun 23, 2011 | 10:45 PM
geddy's uncle's Avatar
Water/methanol injection. You spray a fine-misted fog of water/methanol into the intake horn just prior to the manifold, and it cools the air-charge beyond what the intercooler did for you.
Same principle as nitrous, but less expensive, since you can use cheap blue windshield-washer fluid. And safer, since the refrigerant effect isn't quite as severe as nitrous.
And, you can run it for more seconds continuously, as well
You can also use plain water, if there's no danger of a freeze up due to cold weather
Old Jun 25, 2011 | 11:41 PM
kieron_kohlmann's Avatar
good luck finding a washer pump that exceeds manifold pressure.
Old Jun 26, 2011 | 06:51 AM
Drothgeb's Avatar
Not really.
Old Jun 26, 2011 | 09:05 AM
Originally Posted by Drothgeb
Not really.
Cools the intake charge, is what I meant.
Yes the methanol counts as a fuel, where the nitrous counts as an oxygen source.
Yes, the nitrous is a more pronounced refrigerant than the water.
Those are details intrinsic to the materials themselves, but how, in principle, do the goals differ?
Unless I'm mistaken, water injection dates to WW2 aircraft, and some wise guy said, "that's neat, but I bet laughing gas would be more interesting"
Same principle. Different details.
Like the evolution from James Watt's steam engine to the modern internal combustion engine. The principles still apply.
