Chrysler OBD II Codes (03-07 5.9) 07.5-Cur 6.7 (48re Transmission)
Old Feb 2, 2009 | 08:07 PM
wildbill's Avatar
Default Chrysler OBD II Codes (03-07 5.9) 07.5-Cur 6.7 (48re Transmission)
P0016 Crankshaft/Camshaft Timing Misalignment/Out-of-Sync
P0071 Ambient Temperature Sensor Performance / Rationality
P0072 Ambient Temperature Sensor Low
P0073 Ambient Temperature Sensor High
P0088 Fuel Rail Pressure Too High
P0106 Manifold Absolute Pressure Sensor Performance / Rationality
P0107 Manifold Absolute Pressure Sensor Low
P0108 Manifold Absolute Pressure Sensor High
P0111 Intake Air / Charge Temperature Sensor Performance / Rationality
P0112 Intake Air / Charge Temperature Sensor Low
P0113 Intake Air / Charge Temperature Sensor High
P0116 Engine Coolant Temperature Sensor Performance / Rationality
P0117 Engine Coolant Temperature Sensor Low
P0118 Engine Coolant Temperature Sensor High
P0128 Cooling System Error / Thermostat Rationality
P0148 Fuel Delivery Error
P0169 Water-in-Fuel Detected For Too Long
P0192 Fuel Rail Pressure Sensor Low
P0193 Fuel Rail Pressure Sensor High
P0201 Fuel Injector 1 Circuit
P0202 Fuel Injector 2 Circuit
P0203 Fuel Injector 3 Circuit
P0204 Fuel Injector 4 Circuit
P0205 Fuel Injector 5 Circuit
P0206 Fuel Injector 6 Circuit
P0217 Coolant Temperature Too High
P0219 Engine Overspeed
P0234 Turbocharger Overboost Condition
P0236 Turbocharger Boost Pressure Sensor Performance / Rationality
P0237 Turbocharger Boost Pressure Sensor Low
P0238 Turbocharger Boost Pressure Sensor High
P0251 Injection Pump Fuel Valve Feedback
P0300 Multiple Cylinder Misfire
P0301 Cylinder 1 Misfire
P0302 Cylinder 2 Misfire
P0303 Cylinder 3 Misfire
P0304 Cylinder 4 Misfire
P0305 Cylinder 5 Misfire
P0306 Cylinder 6 Misfire
P0335 Crankshaft Position Sensor Circuit
P0336 Crankshaft Position Sensor Performance
P0337 Crankshaft Position Sensor Circuit Low
P0338 Crankshaft Position Sensor Circuit High
P0340 Camshaft Position Sensor Circuit
P0341 Camshaft Position Sensor Performance / Rationality
P0381 Wait-to-Start Lamp Inoperative
P0461 Fuel Level Sensor 1 Performance / Rationality
P0462 Fuel Level Sensor 1 Low
P0463 Fuel Level Sensor 1 High
P0477 Exhaust Pressure Control Relay Low
P0478 Exhaust Pressure Control Relay High
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
P0483 Cooling Fan Speed
P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1
P0514 Battery Temperature Sensor Performance / Rationality
P0516 Battery Temperature Sensor Low
P0517 Battery Temperature Sensor High
P0521 Oil Pressure Sensor Performance / Rationality
P0524 Oil Pressure Too Low
P0532 A/C Pressure Sensor Low
P0533 A/C Pressure Sensor High
P0541 Intake Air Heater Relay 1 Low
P0542 Intake Air Heater Relay 1 High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0572 Brake Switch 1 Low
P0573 Brake Switch 1 High
P0580 Speed Control Multiplexed Switch 1 Low
P0581 Speed Control Multiplexed Switch 1 High
P0602 Control Module Programming Error/NotProgrammed
P0604 Internal Control Module RAM Integrity Failure
P0606 Internal ECM Processor
P0607 ECU Internal Performance
P0622 Generator Field Control Circuit
P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low
P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High
P0630 VIN Not Programmed in PCM
P0633 SKIM Key Not Programmed in PCM
P0642 Sensor Reference Voltage 1 Circuit Low
P0643 Sensor Reference Voltage 1 Circuit High
P0646 A/C Clutch Relay Circuit Low
P0647 A/C Clutch Relay Circuit High
P0652 Sensor Reference Voltage 2 Circuit Low
P0653 Sensor Reference Voltage 2 Circuit High
P0698 Sensor Reference Voltage 3 Circuit Low
P0699 Sensor Reference Voltage 3 Circuit High
P0700 Transmission Control System (MIL Request)
P0837 Four Wheel Drive (4WD) Switch Performance / Rationality
P0838 Four Wheel Drive (4WD) Switch Circuit Low
P0839 Four Wheel Drive (4WD) Switch Circuit High
P1652 J1850 Communication Bus
P2121 Pedal Position Sensor 1 Performance / Rationality
P2122 Pedal Position Sensor 1 Low
P2123 Pedal Position Sensor 1 High
P2127 Pedal Validation Switch 2 Low
P2128 Pedal Validation Switch 2 High
P2146 Fuel Injector Group 1 Supply Voltage Circuit
P2149 Fuel Injector Group 2 Supply Voltage Circuit
P2266 Water in Fuel Sensor Circuit Low
P2269 Water in Fuel Condition
P2502 Charging System Output Voltage
P2503 Charging System Output Low
P2504 Charging System Output High
P2509 ECM/PCM Power Input Signal Intermittent
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 High
P2609 Intake Air Heater System Performance
Old Oct 10, 2009 | 12:48 PM
wildbill's Avatar
Default OBDII Codes For 07.5-Cur 6.7 Diesels
P-00af-Turbocharger Boost Control Module Performance
P-003a-Turbocharger Boost Control Module Position Exceeded Learning Point
P-006e-Turbocharger Boost Control Module Supply Voltage Circuit Low
P-006f-Turbocharger Boost Control Supply Voltage Circuit High
P-007c-Charge Air Cooler Temperature Sensor Circuit Low
P-007d-Charge Air Cooler Temperature Sensor Circuit High
P-007e-Charge Air Cooler Temperature Sensor Circuit Intermittent/Erratic
P-0016-Crankshaft/Camshaft Timing Misalignment - Bank1, Sensor 1
P-0031-O2 Sensor 1/1 Heater Circuit Low
P-0037-O2 Sensor 1/2 Heater Circuit Low
P-040b-Exhaust Gas Recirculation Temperature Sensor 1 Circuit Performance
P-040c-Exhaust Gas Recirculation Temperature Sensor 1 Circuit Low
P-040d-Exhaust Gas Recirculation Temperature Sensor 1 Circuit High
P-042e-Exhaust Gas Recirculation Control Stuck Open
P-0046-Turbocharger Boost Control Circuit Performance
P-0049-Turbocharger Engine Overspeed
P-051b-Crankshaft Pressure Sensor Circuit Range/Performance
P-051c-Crankshaft Pressure Sensor Circuit Low
P-051d-Crankshaft Pressure Sensor Circuit High
P-061a-ETC Level 2 Torque Performance
P-061c-ETC Level 2 RPM Performance
P-062c-ETC Level 2 MPH Performance
P-063c-Generator Voltage Sense Low
P-063d-Generator Voltage Sense High
P-065a-Geberator System Performance
P-0071-Inlet Air Temp Sensor Rationality-ECM
P-0071-Inlet Air Temp Sensor Performance (TIPM)
P-0072-Inlet Air Temp Sensor Voltage Too Low (ECM)
P-0072-Inlet Air Temp Sensor Circuit Low (TIPM)
P-0073-Inlet Air Temp Sensor Voltage Too High (ECM)
P-0073-Inlet Air Temp Sensor Circuit High (TIPM)
P-0087-Fuel Rail Pressure Too Low
P-0088-Fuel Rail Pressure Too High
P-0101-Mass Air Flow Sensor "a" Circuit Performance
P-0102-Mass Air Flow Sensor "a" Circuit Low
P-0103-Mass Air Flow Sensor "a" Circuit High
P-0106-Manifold Absolute Pressure Sensor Performance
P-0107-Manifold Absolute Pressure Sensor Circuit Low
P-0108-Manifold Absolute Pressure Sensor Circuit High
P-0111-Intake Air Temperature Sensor Performance
P-0112-Intake Air Temperature Sensor Circuit Low
P-0113-Intake Air Temperature Sensor Circuit High
P-0116-Engine Coolant Temperature Sensor Performance
P-0117-Engine Coolant Temperature Sensor Circuit Low
P-0118-Engine Coolant Temperature Sensor Circuit High
P-0128-Thermostat Rationality
P-0131-O2 Sensor 1/1 Circuit Low
P-0135-O2 Sensor 1/1 Heater Performance
P-0137-O2 Sensor 1/2 Circuit Low
P-0141-O2 Sensor 1/2 Heater Performance
P-0148-Fuel Delivery Error
P-0169-Water In Fuel Detected For Too Long
P-0191-Fuel Rail pressure Sensor Circuit Performance
P-0192-Fuel Pressure Sensor Low
P-0193-Fuel Pressure Sensor High
P-0201-Fuel Injector 1 Circuit/Open
P-0202-Fuel Injector 2 Circuit/Open
P-0203-Fuel Injector 3 Circuit/Open
P-0204-Fuel Injector 4 Circuit/Open
P-0205-Fuel injector 5 Circuit/Open
P-0206-Fuel Injector 6 Circuit/Open
P-0217-Coolant Temperature Too High
P-0219-Engine Overspeed
P-0251-Injection Pump Fuel Valve Feedback
P-0300-Multiple Cylinder Misfire
P-0335-Crankshaft Position Sensor Circuit
P-0336-Crankshaft Position Sensor Performance
P-0340-Crankshaft Position Sensor Circuit-Bank 1, Sensor 1
P-0341-Crankshaft Position Sensor Performance-Bank 1, Sensor 1
P-0381-Wait To Start Lamp Inoperative
P-0400-EGR System Flow Malfunction
P-0401-EGR System Performance
P-0402-EGR Flow Excessive
P-0403-EGR Control Circuit/Open
P-0404-EGR Position Sensor Performance Diesel
P-0405-EGR Position Sensor Circuit Low
P-0461-Fuel Level Sensor 1 Performance
P-0462-Fuel Level Sensor 1 Circuit Low
P-0463-Fuel Level Sensor 1 Circuit High
P-0471-Exhaust Pressure Sensor 1 Performance
P-0472-Exhaust Pressure Sensor 1 Low
P-0473-Exhaust Pressure Sensor 1 High
P-0480-Cooling Fan 1 Control Circuit/Open
P-0483-Cooling Fan Speed
P-0487-EGR Airflow Throttle Control Circuit A Open
P-0488-EGR Airflow Throttle Control Circuit Performance
P-0489-EGR Control Circuit Low
P-0501-Vehicle Speed Sensor 1 Performance
P-0505-Engine Speed At Idle-Data Erratic, Intermittent Or Incorrect
P-0513-Invalid Skin Key
P-0514-Battery Temperature Sensor Performance
P-0516-Battery Temperature Sensor Circuit Low
P-0517-Battery Temperature Sensor Circuit High
P-0521-Engine Oil Pressure Sensor Performance
P-0524-Engine Oil Pressure Too Low
P-0532-A/C Pressure Sensor Circuit Low
P-0533-A/C Pressure Sensor Circuit High
P-0541-Intake Air Heater Control Circuit 1 Low
P-0542-Intake Air Heater Control Circuit 1 High
P-0545-Exhaust Gas Temperature Sensor Circuit Low-Bank 1, Sensor 1
P-0546-Exhaust Gas Temperature Sensor Circuit High-Bank 1, Sensor 1
P-0562-Battery Voltage Low
P-0563-Battery Voltage High
P-0571-Brake Switch 1 Performance
P-0572-Brake Switch 1 Stuck On
P-0573-Brake Switch 1 Stuck Off
P-0580-Speed Control Switch 1 Circuit Low
P-0581-Speed Control Switch 1 Circuit High
P-0585-Speed Control Switch 1/2 Correlation
P-0592-Speed Control Switch 2 Circuit Low
P-0593-Speed Control Switch 2 Circuit High
P-0601-Internal Memory Checksum Invalid
P-0604-Internal Control Module Ram
P-0606-Internal Control Processor
P-0607-ECU Internal Performance
P-0622-Generator Field Control Circuit/Open
P-0628-Fuel Pump Control Circuit Low
P-0629-Fuel Pump Control Circuit High
P-0630-VIN Not Programmed In PCM
P-0633-Skim Secret Key Not Stored In PCM
P-0642-Sensor Reference Voltage 1 Circuit Low
P-0643-Sensor Reference Voltage 1 Circuit High
P-0646-A/C Control Circuit Low
P-0647-A/C Control Circuit High
P-0652-Sensor Reference Voltage 2 Low
P-0653-Sensor Reference Voltage 2 High
P-0698-Sensor Reference Voltage 3 Circuit Low
P-0699-Sensor Reference Voltage 3 Circuit High
P-06a4-Sensor Reference Voltage 4 Circuit Low
P-06a5-Sensor Reference Voltage 4 Circuit High
P-0700-Transmission Control System (MIL Request)
P-0850-Park/Neutral Switch Performance
P-1011-Fuel Pump Delivery Pressure Too Low
P-1012-Fuel Pump Delivery Pressure Too High
P-1191-Inlet Air Temperature Sensor Rational/Performance
P-1192-Inlet Air Temperature Sensor Low
P-1193-Inlet Air Temperature Sensor High
P-113c-O2 Sensor Power Supply Circuit Performance
P-125a-Power Enable Control Circuit Low
P-125b-Power Enable Control Circuit High
P-1272-A/C Clutch Control Circuit 2 Low (TIPM)
P-1273-A/C Clutch Control Circuit 2 High (TIPM)
P-1274-A/C Clutch Control Circuit 2 Open (TIPM)
P-1275-A/C Clutch Control Circuit 2 Overcurrent (TIPM)
P-1277-Starter Control Circuit 2 Low (TIPM)
P-1278-Starter Control Circuit 2 High (TIPM)
P-1279-Starter Control Circuit 2 Open (TIPM)
P-127a-Starter Control Circuit 2 Overcurrent (TIPM)
P-127c-Fuel Pump Control Circuit 2 Low (TIPM)
P-127d-Fuel Pump Control Circuit 2 High (TIPM)
P-127e-Fuel Pump Control Circuit 2 Open (TIPM)
P-127f-Fuel Pump Control Circuit 2 Overcurrent (TIPM)
P-141a-Exhaust Gas Temperature Sensor 1 And 2 Signals Swapped
P-144e-EGR Cooler Bypass Status Line Circuit Low
P-144f-EGR Cooler Bypass Status Line Circuit High
P-1451-Diesel Particulate Filter System Performance
P-1484-Catalyst Overheat Detection
P-1506-Crankcase Depression Regulator Valve Performance
P-1507-Crankcase Filter Restriction
P-1508-Crankcase Filter Restriction-Replace Filter
P-2000-NOX Absorber Efficiency Below Threshold-Bank 1
P-2002-Diesel Particulate Filter Efficiency Below Threshold
P-200c-Diesel Particulate Filter Over Temperature-Bank 1
P-200e-Catalyst System Over Temperature-Bank 1
P-2032-Exhaust Gas Temperature Circuit Low-Bank 1, Sensor 2
P-2033-Exhaust Gas Temperature Sensor Circuit High-Bank 1, Sensor 2
P-2080-Exhaust Gas Temperature Sensor Circuit Performance-Bank 1. Sensor1
P-2084-Exhaust Gas Temp Sensor Circuit Performance- Bank 1, Sensor 2
P-2121-Accelerator Pedal Position Sensor 1 Performance
P-2122-Accelerator Pedal Position Sensor 1 Circuit Low
P-2123-Accelerator Pedal Position Sensor 1 Circuit High
P-2127-Accelerator Pedal Position Sensor 2 Circuit Low
P-2128-Acclerator Pedal Position Sensor 2 Circuit High
P-2141-EGR Airflow Throttle Control Circuit Low
P-2142-EGR Airflow Throttle Control Circuit High
P-2227-Barometric Pressure Sensor Rationality
P-2228-Barometric Pressure Circuit Low
P-2229-Barometric Pressure Circuit High
P-2262-Turbocharger Boost Pressure Not Detected-Mechanical
P-2266-Water In Fuel Sensor Circuit Low
P-2267-Water In Fuel Sensor Circuit High
P-2269-Water In Fuel Condition
P-2299-Brake Pedal Position/Accelerator Pedal Position Incompatible
P-242b-Exhaust Gas Temp Sensor Circuit Performance-Bank 1, Sensor 3
P-242c-Exhaust Gas Temp Sensor Circuit Low-Bank 1, Sensor 3
P-242d-Exhaust Gas Temp Sensor Circuit High-Bank 1, Sensor 3
P-242f-Diesel Particulate Filter Restriction-Ash Accumulation
P-244a-Diesel Particulate Filter Differential Pressure Too Low
P-244d-Exhaust Temperature Too High For Particulate Filter Regeneration
P-2453-Diesel Particulate Filter Pressure Sensor A Circuit Performance
P-2454-Diesel Particulate Filter Pressure Sensor A Circuit Low
P-2455-Diesel Particulate Filter Pressure Sensor A Circuit High
P-2457-Exhaust Gas Recirculation Cooling System Performance
P-245a-EGR Cooler Bypass Control Circuit Open
P-245c-EGR Cooler Bypass Control Circuit Low
P-245d-EGR Cooler Bypass Control Circuit High
P-2463-Diesel Particulate Filter-Soot Accumulation
P-2503-Charging System Output Low
P-2504-Charging System Output High
P-2509-ECM/PCM Power Input Signal Intermittent
P-254c-PTO Speed Selector Sensor Circuit Low
P-254d-PTO Speed Selector Sensor Circuit High
P-2579-Turbocharger Speed Sensor Circuit Performance
P-2580-Turbocharger Speed Sensor Circuit Low
P-2609-Intake Air Heater System Performance
P-268c-Cylinder 1 Injector Data Incompatible
P-268d-Cylinder 2 Injector Data Incompatible
P-268e-Cylinder 3 Injector Data Incompatible
P-268f-Cylinder 4 Injector Data Incompatible
P-2690-Cylinder 5 Injector Data Incompatible
P-2691-Cylinder 6 Injector Data Incompatible
P-2a00-O2 Sensor 1/1 Circuit Performance
P-2a01-O2 Sensor 1/2 Circuit Performance
Old Oct 20, 2009 | 12:01 AM
wildbill's Avatar
Default 48RE A/T Trouble Codes (Diesel)
P0711-TRANS TEMP SENSOR, NO TEMP RISE AFTER START (DIESEL.)
P0712-TRANS TEMP SENSOR VOLTAGE TOO LOW (DIESEL)
P0713-TRANS TEMP SENSOR VOLTAGE TOO HIGH
P0720-LOW OUTPUT SPEED SENSOR -RPM ABOVE 15 MPH (DIESEL)
P0748-PRESSURE SOL CONTROL/TRANS RELAY CIRCUITS (DIESEL)
P0850-P/N SWITCH PERFORMANCE (DIESEL)
P0868-GOVERNOR PRESSURE SENSOR VOLTS TOO HI (DIESEL)
P0869-GOVERNOR PRESSURE SENSOR VOLTS TOO LOW (DIESEL)
P0882-TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT LOW (DIESEL)
P0883-TRANS 12 VOLT SUPPLY RELAY CONTROL CIRCUIT HIGH (DIESEL)
P0973-TRANSMISSION OVERDRIVE CIRCUIT VOLTAGE TOO LOW (DIESEL)
P0974-TRANSMISSION OVERDRIVE CIRCUIT VOLTAGE TOO HIGH (DIESEL)
P128B-TCM POWER CONTROL CIRCUIT 2 LOW - TIPM
P128C-TCM POWER CONTROL CIRCUIT 2 HIGH - TIPM
P128D-TCM POWER CONTROL CIRCUIT 2 OPEN - TIPM
P128E-TCM POWER CONTROL CIRCUIT 2 OVERCURRENT - TIPM
P1740-TCC O/D SOL PERFORMANCE (DIESEL)
P1749-TRANSMISSION THROTTLE VALVE POSITION SENSOR CIRCUIT LOW
P1750-TRANSMISSION THROTTLE VALVE POSITION SENSOR CIRCUIT HIGH
P1751-TRANSMISSION THROTTLE VALVE POSITION MINIMUM RANGE PERFORMANCE
P1752-TRANSMISSION THROTTLE VALVE SPAN PERFORMANCE
P1753-TRANSMISSION THROTTLE VALVE MECHANICAL PERFORMANCE
P1754-TRANSMISSION THROTTLE VALVE ACTUATOR STUCK
P1755-TRANSMISSION THROTTLE VALVE CONTROL CIRCUIT
P1756-GOV PRESS NOT EQUAL TO TARGET @ 35 - 40 PSI (DIESEL.)
P1757-GOV PRESS ABOVE 3 PSI IN GEAR WITH 0 MPH (DIESEL)
P1762-GOV PRESS SENSOR OFFSET VOLTS TOO LOW OR HIGH (DIESEL)
P2769-TRANSMISSION TCC CONTROL CIRCUIT LOW
P2770-TRANSMISSION TCC CONTROL CIRCUIT HIGH (DIESEL)
