fuel pressure guage
Old Jan 30, 2009 | 07:57 PM
dan33klein's Avatar
Default fuel pressure guage
hey guys i have a 96 12 valve and im wondering were i install the electronic sensor for my fuel pressure guage?
i seen a picture of the 24 valves that have bolts in the top of the fuel filter you just unscrew and screw the sensor in. my 12 valve doesnt have that. what should i do?
Old Jan 30, 2009 | 08:37 PM
Number 1 - return that fuel pressure guage. You want a mechanical guage as you will find your electric senders will not last on a 12V, as they get hammered with pressure spikes.
The best thing to do is pull out the banjo bolt on the P-7100 inlet, get a letter drill bit (size R), and tap it 1.8" npt. You will want to install a needle valve to dampen the pressure spikes from the P-7100 and run it barely cracked. Heres a pic:
Old Feb 15, 2009 | 03:10 PM
dodgecummines12valv's Avatar
hi i have a 94 cummins 12 valv i want to no were i can find that Screw were you turn the fuil up
Old Feb 15, 2009 | 07:29 PM
94cummins12v's Avatar
search in other posts
Old Feb 15, 2009 | 10:13 PM
Dodgehunter84's Avatar
I agree with Dr. Evil, get a mechanical guage, I put a electronic gauge in 24v and it only lasted a couple of months. The senders don't hold up to the viberations these engines make.
Old Feb 15, 2009 | 10:23 PM
Mech gauge with Isolator works the best IMHO
Old Feb 16, 2009 | 12:09 AM
i was thinking of using an isolator but i cant figure out how to make the damn thing work, i am going to just run 1/4" DOT air break line to it
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
