04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
boost gague????
Old Jan 29, 2009 | 02:07 PM
GTRW3T's Avatar
Default boost gague????
ok im looking at puting at pyrometer and a boost gague in my truck. ive been trying to figure out how to hook the boost gague up onto a duramax. is there anyone that can help me out because im lost..
Old Jan 29, 2009 | 03:37 PM
The air inlet casting to tap is located on the top of the motor under the black plastic emblem cover. Remove the cover and the blue intercooler boot that connects the casting to the passenger side intercooler pipe.
Luke
Old Jan 29, 2009 | 08:17 PM
GTRW3T's Avatar
thanks luke
Old Jan 29, 2009 | 11:18 PM
2500HeavyDuty's Avatar
some people drill and tap the ic tubes, but they seem a little thin to me
Old Jan 30, 2009 | 08:50 AM
GTRW3T's Avatar
by any chance do you have them in your truck? if so how did you hook them up?
Old Jan 30, 2009 | 09:09 AM
Oilfield_Mafia's Avatar
I drilled and tapped the big cast piece in the IC system.. I believe the LLY has the same piece. I'll see if I can find you a picture.
Old Jan 30, 2009 | 09:11 AM
Here ya go bud.. you can see I drilled and tapped, be sure if you do the same thing, to remove the boot from the bottom of this piece, and stuff a rag in it, to that the shavings dont get stuck in the IC system.. then wash it out through the hole with some WD-40.
Old Jan 30, 2009 | 12:25 PM
GTRW3T's Avatar
thanks buddy that pic is alot of help.
stewart.william.c
Feb 11, 2015 01:39 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Crews8r
Dec 21, 2014 07:35 AM
offroad00
24
Oct 23, 2014 03:28 PM
