Gelling Fuel Epidemic - ATTN !!!!
Old Jan 20, 2009 | 05:13 AM
DB Admin's Avatar
Banned
Default Gelling Fuel Epidemic - ATTN !!!!
I dont know if its the USLD or if the Government/ Fuel Companies are boning us with the Winter Blend Fuel but Somethings going on , Just this week i have heard reports of 2 CTD , 1 DMD and 4 PSD Fuel Gelling , all in Ohio but 1 thats in Indy
Get Your Power Service , Stanadyne , Sea Foam or what ever in there NOW !!
Old Jan 20, 2009 | 05:29 AM
Jazz's Avatar
From what I've been hearing it is the new USLD fuel doing it
Old Jan 20, 2009 | 06:07 AM
Cummins97's Avatar
I had mine gell up on me a few days ago. Got down to below 0 a couple nights. After sitting for both nights it was pretty gelled up. She got a healthy dose of PS, and a new FF out of it.
Old Jan 20, 2009 | 06:37 AM
Hummin Cummins's Avatar
My truck didn't Jell up when it got down over -40*f straight #2 with Howes. The only time I ever Jelled up was with my 04 at around -25*f. I ran out of conditioner so I filled it a little over 1/2 #1. Havent run a gallon of the water since.
Old Jan 20, 2009 | 08:06 AM
gunman41mag's Avatar
Moderator
How cold does it have to get for diesel to gell ??? Guys I'm not trying to be a smart-a$$, I live in MIAMI & never had diesel gell up on me ???
Old Jan 20, 2009 | 08:18 AM
H1 Bomber's Avatar
It depends on the grade of diesel fuel, the additives in the fuel, and water contamination.
When the temperature drops, wax crystals can form in the fuel, plugging the fuel filter and/or fuel line. This will prevent the engine from running.
Diesel fuel #2 should resist gelling down to about -10 deg. F (-23 deg. C), while winter blends of diesel fuel #2 and fuel #1 (kerosene) can typically handle temperatures down to -4 degrees F to -20 deg. F. But some "winter" blends may gel at higher temperatures if it contains too much #2 diesel and not enough #1 (say around 18 to 20 degrees F).
The pour point of the fuel (the point at which it starts to gel) can be lowered by additives, and by using heaters in the fuel filter, fuel tank and around the fuel line.
Old Jan 20, 2009 | 08:42 AM
Moderator
HI H1 Bomber, THANK YOU I won't have a problem then, cause the record cold here is 32 degrees !!!!
Old Jan 20, 2009 | 08:47 AM
MRaynor's Avatar
For those of you that missed it.
https://www.dieselbombers.com/genera...ther-info.html
Old Jan 20, 2009 | 08:57 AM
wildbill's Avatar
#1 isn't near kerosene. But the best way to keep from gelling, is straight #1 with 2 stroke oil or some other type of lubricant.
Old Jan 20, 2009 | 09:43 PM
woodsrat's Avatar
I would say ohio got some bad ****. We had 27 fuel related service calls in three days when we had the cold snap.
