Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Firestone Ride-Rite Air Bags
Old Jan 19, 2009 | 02:49 PM
TBone's Avatar
Default Firestone Ride-Rite Air Bags
I have a 2006 GMC Sierra 2500HD with Firestone air bags. I tow a 34' 5th wheel that's about 11k lbs. How much air should I run in the bags? 100 psi is max.
Thanks, Tony
Old Jan 19, 2009 | 10:36 PM
madmanwithmouse's Avatar
Got them on my 3500, and with a 40ft 13k trailer, i run around 45-50 empty trailer.
40psi is probly a good starting point, relly have to just run them and adjust to suite ya. If you are going on a long trip set them around 60 that way you can let the air out till ya like it. Personaly i got the compressor on mine so I can adjust on the fly to suite me.
Old Jan 25, 2009 | 12:41 AM
TBone's Avatar
thaks for the info. I've been playing with different psi's and haven't found the sweet spot yet. I was to cheap to buy the onboard compressor so I do it manually.
Old Mar 9, 2009 | 08:49 AM
silverram323's Avatar
When i haul heavy i usually start around 60-70 psi and go from there. I also have a onboard air compressor.
Old Mar 16, 2009 | 01:18 PM
Mr.Krabs's Avatar
I'm going to try adding a tank for the air to expand into,see if I can't smooth mine out.
I've noticed that unless I'm hauling something ridiculous I don't need em'
Old Mar 17, 2009 | 01:52 PM
AlCorr's Avatar
I have a 10,000 5er and only put 30-40lb, any more than that is too hard on my back.
Old Apr 18, 2009 | 08:05 AM
AABEAR's Avatar
I am new on here. I was think about firestone on my truck. This will help me out.
Old May 13, 2009 | 01:05 PM
AlCorr's Avatar
Get a on-board air compressor, well worth the money.
Old May 31, 2009 | 08:24 PM
TRG's Avatar
TRG
Did you ever sell the air system off of the F150, that you had posted?
Old May 31, 2009 | 10:25 PM
sawyer45306's Avatar
I had a set on another truck I used to own, it was a 1/2 ton and I would load that truck with firewood and run 60 lbs usually and it never would drop.
