13 second 1/4s ??
Old Jan 9, 2009 | 01:49 PM
muz's Avatar
muz
Default 13 second 1/4s ??
How much further will I need to go to get my 12valve into the 13s?? TIA
Old Jan 10, 2009 | 06:33 AM
97 D-Tec's Avatar
what are your times now?
Old Jan 10, 2009 | 02:08 PM
muz's Avatar
muz
I don't know I have yet to get it to the strip. I just need some ball park figures to aim for?
Old Jan 10, 2009 | 04:05 PM
94cummins12v's Avatar
alot more than what you have done thats for sure
Old Jan 11, 2009 | 09:20 AM
hereismylife's Avatar
lmao..... I think he knows that already though....
Old Jan 12, 2009 | 11:53 PM
9712valve's Avatar
have it timed to 16.5*, buy a set of 4000rpm governor springs, and a set of ddp 90hp or 140hp injectors or set of marine 370's if you don't have the money for the dynomite diesel injectors. that should put you in the 13's, but if you do a lot of towing you may want to upgrade your turbo to something such as bd super b. also depending on what your ultimate goal is you may want the ddp 4's which are the 140hp injectors. good luck.
Old Jan 13, 2009 | 12:44 AM
love my 370's awsome power, you would be a tad faster because of your auto were i got a 5 speed
Old Jan 13, 2009 | 02:10 PM
muz's Avatar
muz
Thanks for the replies! I got the 4k govenor springs on order, will all this get me into egt melt down & if so is a bigger exhaust housing for the turbo going to help out much?? Also I had a billet input put in the tranny but could'nt afford the billet flex plate I guess I'm guna need one now?
Old Jan 13, 2009 | 05:47 PM
stillbad's Avatar
Get some 60lb valve springs to go with those 4ks. Bigger injectors as said, a set delivery valves, bigger turbo and exhaust to help out with all that.
Old Jan 14, 2009 | 02:17 AM
9712valve's Avatar
it will get your egt's hot if you hold it wideo open for 30seconds or so, but just don't hold it wide open for too long, if you max out your 1500 degree gauge for a 1/4 miles your engine won't melt down, it will be fine, but you will have to watch the gauge, unless you upgrade your turbo, you probably wanna do the billet flex plate as soon as you can, its cheap insurance.
