twins
Old Jan 5, 2009 | 09:12 PM
94cummins12v's Avatar
Default twins
ok guys im wanting to build twins for my truck and want to leave my pacbrake on would it "KILL" my pacbrake buy putting a CAT (80-somthing-20)turbo under it its off a D10? to me the concept will still be there for the breaking by making more backpressure on the upper turbo (current hx35/40 hybrig w non-gated 16cm housing) whats everyones opinion on this
Old Jan 5, 2009 | 09:25 PM
Which Pacbrake is it? 3" elbow mount? or inline?
Old Jan 5, 2009 | 09:29 PM
its the 3 inch elbow mount, what i was thinkin is making a custom pipe to bolt directly onto the pacbrake then to the CAT turbo flange
Old Jan 5, 2009 | 10:58 PM
Lil Dog's Avatar
Thats interesting.. I don't know how well the primary turbo would like it when it closes. That would be some fun trying to weld or make a connection from the donut flange to the primary.
Old Jan 6, 2009 | 11:51 AM
sstockton's Avatar
I've seen a lot of guys run them off the bottom charger. What exact turbo are you running? you'll want to get some specs and a map for it.
Sean
Old Jan 6, 2009 | 10:59 PM
dont know what the exact size is but it will need a 5" downpipe wich the break will not fit on it
Old Jan 7, 2009 | 02:21 PM
sstockton's Avatar
I've seen guys running 5" brakes is what I was getting at, but to keep your existing brake, you might be hard pressed to fit it all in there.
Sean
12 valve 97
21
Jan 27, 2016 04:59 PM
