what is up with this thing
Old May 14, 2007 | 09:21 PM
2001shrtbedcummins's Avatar
Default what is up with this thing
It cuts out at high rpms low rpms whenever it feels like it check this vid out http://s28.photobucket.com/albums/c2...t=MOV01023.flv it shows it in it's finest.
Old May 14, 2007 | 10:04 PM
Benjamin's Avatar
Bombardier
i'm taking a stabb in the dark here but what's your fuel pressure? does the rotary pump have an overfolw valve like a p-pumed motor? maybe a bad lift pump? maybe air in the lines...... smoke when it does it? or no smoke?
Old May 14, 2007 | 10:09 PM
no smoke really when it does it just black smoke cuz I floor it to try to right it. I don't really know what the fp is reading as I don't have a gauge. but could you explain the overflow valve?
Old May 14, 2007 | 10:12 PM
guroo987's Avatar
change fuel filter first. than try an apps adjustment and reset. NEED TO KNOW WHAT FUEL PRES IS! might have a injection pump going out. go to an autozone or kragen etc and have the codes pulled and get back to us.
Old May 14, 2007 | 10:21 PM
sorry...this is my 91 can't really do the underhood throttle with a vp pump...besides I don't need one of those "overvalved" trucks.
Old May 14, 2007 | 10:27 PM
Cowboy_Customs's Avatar
I dont believe the lift pump would do that. The VE has the capability of drawing its own fuel, just makes it a dog. Possibly the governer spring, but I suppose Id be more inclined to believe the IP is on its way out. I'll ask some folks n see what I come up with for you.
Old May 14, 2007 | 10:38 PM
what would cause the ip to go out though?
Old May 15, 2007 | 06:46 AM
ttt
Old May 16, 2007 | 10:02 AM
OK, I got with a friend of mine that knows much more then i do. It could be a clogged fuel filter, or bad lift pump. Does it start generaly easy? It could possibly be air in the lines as well. Just basically isnt getting fuel.
Try some of these, replace filter, install fuel pressure guage, put in a section of clear hose in the fuel line. (the closer to the IP the better) I dont know how to really test the lift pump, but I would assume you could pull the outlet, and use the manual prime lever and see if it is putting anything out. If that ends up being it, not a bad time to upgrade to a 2nd gen 12valve piston pump.
The IP could go with age. How many miles r on it?
Old May 16, 2007 | 06:02 PM
it starts great runs great when you ease it up to 50 anything over 1/4 throttle or 50 mph it cuts out. It's a bad lift pump I believe. Already changed fuel filter already bled the injectors.
