04.5-05 LLY Performance Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines Related To Performance And Longevity
k & n fipk
Old Dec 25, 2008 | 12:43 AM
DIRTYMAX2004's Avatar
Default k & n fipk
i am runnin k & n fipk and was wonderin if there is a better filter that i can use to replace the k & n
Old Dec 25, 2008 | 01:28 AM
Oilfield_Mafia's Avatar
Your stock filter actually filters better than anything and flows plenty of air to support 500 rwhp.. If you still have your stock box and filter you can modify it for the most flow easily.
I did a writeup on the LLY/LBZ Box Mod you can view it here>> https://www.dieselbombers.com/chevy-...LBZ+AIrbox+Mod
For a litle proof on how good the stock filter is compared to the aftermarkets, check this out >> https://www.dieselbombers.com/durama...er+Filter+Test
But if you are dead set on using an aftermarket filter, I personally like the S&B intakes to best.
Old Dec 25, 2008 | 08:33 AM
Rttoys's Avatar
Yep, stock box and filter flow the best...
Old Dec 26, 2008 | 07:43 PM
2500HeavyDuty's Avatar
modded stocker ftw
Old Dec 28, 2008 | 06:19 PM
Sea97Stroker's Avatar
I added a Stock LBZ air cleaner to mine but you will have to mod the Maf tables with efi live..
