VW Diesels Discussion of all things Volkswagen Diesel - TDI, Bug , Touareg , Jetta , Golf , Passat
My Mk3 TDI Corrado
Old Dec 17, 2008 | 07:19 PM
G60ING's Avatar
Default My Mk3 TDI Corrado
Day 1 of ownership of this 59k mile 1990 G60 corrado:
The next morning (I work at night in the Summer):
The Donor:
The Finished Product:
Some of the Mods:
PP764 injector Nozzels
Euro PD Intake Manifold
Custom Race Pipe (EGR Deleted)
Custom IC pipes
2.25" tectonics exhaust Cat Back with Borla Muffler
high pressure fuel pump
Futue Mods:
Turbo
Downpipe/Cat
Chips
For more pictures of the car and its build:
http://share.shutterfly.com/action/w...=8CZtXDdy5asRc
Old Dec 17, 2008 | 07:25 PM
wildbill's Avatar
The 90 G60 on top, you just swap in a bigger plant?
Old Dec 17, 2008 | 07:53 PM
G60ING's Avatar
The G60 is a Gas engine. I converted the car to Diesel Items that have to be modified/swapped to preform the swap:
Modify the gas tank to fit the larger Nozzel
Swap Evaporators to allow for the tdi a/c lines
had a custom a/c line built between the condensor and compressor
swap the gas pedal cluster for a Psaat TDI pedal cluster (drive by wire)
Swap the instrument cluster and its wiring
Swap the engine bay harness (I used a Passat harness because the passat's firewall hoes match the Corrado more then the mk3 Jetta)
Swapped the K-Frame for a Mk3 TDI
Swapped front sub-frame for a passat's
Used an Eco-Diesel Airbox
Built custom IC pipes and used a G60 IC
Swapped in the TDI Motor and transmission from the Donor
Deleted the 5th injector wiring from the passat harness
I also installed:
Coilovers
R32 Control arm bushings
Audi TT Wheels
Eurolights as well as all new lights all the way around
Mk3 Radio
Moonroof
Converted to 5lug
stainless steel brake lines
I built this TDI Corrado too:
1992 VW Corrado SLC With TDI Engine Swap - Smoke Signals
Old Dec 18, 2008 | 12:21 PM
Very, Very nice
Old Dec 18, 2008 | 09:20 PM
Buckshotmckee's Avatar
Sma't Alec!
Very nice!
Old Jan 7, 2009 | 06:34 AM
GTIRHD's Avatar
nice car dood, looks real sharp!
a friend of mine is building a TDI corrado as we speak
Customobsessions.com
Feb 12, 2015 01:10 PM
Dec 22, 2014 09:00 AM
Dec 8, 2014 08:10 AM
Oct 9, 2014 08:10 AM
