TEST ON 6.7 BY KTPERFORMANCE
Old Dec 12, 2008 | 11:41 AM
kcpanages's Avatar
Default TEST ON 6.7 BY KTPERFORMANCE
HELLO GUYS MY NAME IS KRIS. I LIVE HERE IN LOUISIANA. IM HERE TO LET YALL KNOW THAT IM THE OFFICAL LAB RAT FOR KENNY @ KTPERFORMANCE..... SO FAR WE HAVE RAN THE AIRAID CAI WITH NO PROBLEMS AND NO GLITCHES. WE ARE RUNNING A DPF-R DELETE SYSTEM WITH NO PROBLEMS. WE ALSO HAVE THE MBRP DPF BACK 4" MUFFLER DELETE.
TO MONITOR ENGINE READINGS WE HAVE INSTALLED A PILAR MOUNT WITH A DASH HAWK. WE HAVE HAD A FEW PROBLEMS WITH THE SCREEN GOING BLACK BUT BELIEVE WE HAVE THAT SOLVED. WE WERE RUNNING A SUPER CHIPS FLASH PAQ AND HAD NOTHING BUT PROBLEMS. IN THE BEGINING OF JANUARY WE WILL BE PUTTING MY TRUCK ON THE DYNO TO GET SOME BASE READINGS WITH THE DPF DELETE. THEN WE WILL BE INSTALLING AN EDGE JUICE W/ATTITUDE. AFTER THE EDGE IS INSTALLED WE WILL BE DOING A COMPLETE EGR COOLER. STAY TUNED FOR UPDATES
Old Dec 12, 2008 | 02:14 PM
Az2500Cummins's Avatar
Right on man. Did you delete the EGR yet? Which delete kit do you have? H&S or BADP?
I just finished my stage II H&S today, but have not yet done the EGR delete. I am a little nervous.
Last edited by Az2500Cummins; Dec 12, 2008 at 02:14 PM. Reason: Automerged Doublepost
Old Dec 12, 2008 | 07:41 PM
KT Performance's Avatar
Site Sponsor - KT Performance
We are running a DPF-R delete kit.
Old Dec 12, 2008 | 08:42 PM
Compcowboy's Avatar
congrats man. That 6.7 will appreciate it.
Old Dec 12, 2008 | 09:09 PM
dodgeram082500's Avatar
conagrats your motor will love you for it
Old Dec 15, 2008 | 05:43 AM
kcpanages's Avatar
to let some of the guys know we are setting up this truck with a setup for an everyday driver and the fellas that do alot of towing
**UPDATE**
one thing we have found was that the DPF-R system doesnt delete the secondary cat with their dpf delete pipe... i had to do some modifications to get the secondary cat removed and to get the dpf delete pipe to work with my 4" MBRP dpf back muffler delete..........
here is a vid on how the instalation is done with just the dpf delete pipe
Old Dec 19, 2008 | 04:58 AM
kcpanages's Avatar
*update*................. we are having a few glitches with the dpf delete with the pass through connectors.............. also there are some guys trying to mix moduales set up and they are running into problems...... i will be doing some changes on Dec.30 and will update yall on what we are doing
Old Dec 19, 2008 | 07:54 AM
Broke Down's Avatar
dude that things has no power..... figured i could mess with you.
Old Dec 19, 2008 | 07:57 AM
kcpanages's Avatar
na it has a lil power
Old Dec 19, 2008 | 08:14 AM
Broke Down's Avatar
