Dodge transmission issue
Hello,
Just bought an 2007.0 Cummins w/ 48re, still bone-stock, 50,000 miles noticing a couple of subtle transmission issues.
(1) Under slow acceleration the transmission will hesitate between gears, a slight "back-and-forth" motion, or a lurching motion, is noticed. The lurching motion will continue until the accelerator is depressed further, when the transmission will finally shift into the next gear. Only noticeable in first couple of gears.
(2) At highway speeds a similar lurching motion is noticed when traveling on slight downhill grades. The hesitation will continue until the truck is driven past the downhill grade.
Checked transmission fluid, it needs just a little bit of fluid due to a leaking transmission seal, not very much probably less than a 0.5 quart. Haven't had time to purchase fluid lately with my work schedule, but it will get topped off ASAP.
Any advice will be greatly appreciated!
This seems to be becoming a common issue. Mine and a friend of mine both had this happen within the last 2 months.
I didn't notice it on my until I took it in for a tranny flush. He tightened a loose band and after that the problem showed up. Took it back and had him loosen it back up to see if it went away. It got worse. He then hooked up some diagnostic computer. Ended up deciding that the govenor solenoid was bad or going bad?. Replaced it $300 later and that took care of. Same fix for my friend. I had 68000 miles and I think he was around 74000. MInes an 05 and his was an 04, both with the 48RE tranny.
There are a few TSB's out for what you are describing. Perhaps they will assist you in diagnosing and fixing this problem. Hope this helps you out
TSB 21-009-07
TSB 21-019-07
TSB 21-009-07
TSB 21-019-07
NOT SURE ABOUT A 2007 But here the 2nd gen procedure
Dodge Diesel Transmission tips
On of the most frequent questions I get on the Cummins powered Dodge trucks is transmission related. The Dodge automatic tranny is very robust and does what it was intended to do very well. But given the reputation for massive torque that the Cummins engine provides, many times the transmission is asked to do far more that the engineers at Dodge designed it to do. The best thing you can do to make the transmission last a LONG time is 1) Don't exceed what is recommended in towing, 2) Change, change, change that tranny fluid and filter, 3) keep the bands adjusted. What? you did not know that the Chrysler rear wheel drive units required periodic band adjustments?
Both Ford and GM use a different system that does not require band adjustment. Just think about it like the comparison between hydraulic and sold cam lifters. One needs adjustment and one does not. But when a solid lifter engine is adjusted properly, just you watch out!
I recommend a fluid change at 10k if you tow heavy. Fluid is cheap compared to rebuilding a tranny. I had a friend some time ago that rebuilt trannys for a living and asked him this. What is the one thing that would put you out of business? He said people changing their fluid often. Automatics get a bad rap, but most people I query on their change intervals brings up one glaring fact. THEY DON'T CHANGE THEIR FLUID OFTEN ENOUGH!
So lets talk band adjustment. The front and rear bands need adjusting at every 24k miles with your fluid change. If heavy towing I would cut that in half. It is an easy procedure once you see how it is done. So follow along with the pics and let me show you how its done....
Keep in mind that these adjustments were done on a '98 24v truck. Depending on the year
Band adjustments for each model year: These were borrowed from the TDR page.- 1994
- Front Band - tighten to 72 in-lb, back off 2-1/2 turns
- Rear Band
- 32/42RH - Tighten to 72 in-LB, back off 4 turns
- 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
- 1995
- Front Band
- 42RH - tighten to 72 in-lb, back off 2-1/4 turns
- 46RH - tighten to 72 in-lb, back off 2-7/8 turns
- 47RH - tighten to 72 in-lb, back off 1-7/8 turns
- Rear Band
- 42RH - tighten to 72 in-lb, back off 4 turns
- 46RH - tighten to 72 in-lb, back off 2 turns
- 47RH - tighten to 72 in-lb, back off 3 turns
- Front Band
- 1996
- Front Band - tighten to 72 in-lb, back off 2-7/8 turns
- Rear Band - tighten to 72 in-lb, back off 2 turns
- 1997 [From: "Paul R. Haller" To: DiRT]
- Front Band
- 46RE - tighten screw to 8N.m or 72 inch pounds, back off 2 7/8 turns
- 47RE - tighten screw to 8N.m or 72 inch pounds, , back off 1 7/8 turns
- Rear band
- 46RE - tighten screw to 8N.m or 72 inch pounds, back off 2 turns
- 47RE - tighten screw to 8N.m or 72 inch pounds, back off 3 turns
- The adjustment screw inside the case is a square head bolt. You will need a special 1/4 square head socket to fit your torque wrench.
- Front Band
- 1998 unknown
- 1999
- Front Band
- 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
- 42 RE - The final adjustment for the front band has been changed to:
- back off 3 turns. (TSB 21-16-98)
- Rear Band
- 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
- The 47RH rear band requires a 1/4" hex driver, the front band requires a T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx driver
- Front Band
- 2000-2001
- Front Band
- 42RE - Tighten to 72 in-lb, back off 3 turns
- 44RE - Tighten to 72 in-lb, back off 1 7/8 turns
- 46RE - Tighten to 72 in-lb, back off 2 7/8 turns
- 47RE - Tighten to 72 in-lb, back off 1 7/8 turns
From Bill Konolday's 47RE notes: I usually go a little looser than factory specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns. Depending on the circumstances I have backed off the band up to 2 1/2 turns.
- Rear Band
- 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
- 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
- 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
- Front Band
These 2 pics show the lock nut and the adjusting torx T-40 screw.
This is the front band adjustment on the drivers side of the transmission.
Disengage the spring from the lever so your wrench will have some working room.
Back off the nut about 5 turns and then torque the torx screw to 72 inch lbs. Then
I backed off the torx screw (1 7/8 turns). You must do this! Failure to back off the
torx will result in transmission damage! Then re torque the nut 30ft lbs. Don't forget
to re attach the spring to the lever.
Remove the tranny pan and filter to access the rear band adjustment.
Back off the nut about 5 turns and torque the torx screw to 72 inch lbs. Then
I backed off the torx screw (3 turns). You must do this! Failure to back off the
torx will result in transmission damage! Then re torque the nut 25ft lbs.
Install the new filter and pan, refill with ATF+4 and enjoy!
Great info Dieselminded-will have to adjust them!
Will have to have that replaced. From what everyone is saying, seems like a common issue on these!
