Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Lets Talk Turbo inducers and Exducers
Old Dec 5, 2008 | 02:33 PM
RSWORDS's Avatar
Default Lets Talk Turbo inducers and Exducers
To understand why and how one compressor wheel flows differently than another, you need to understand the anatomy of the wheel itself. Let's take a look at the following picture:
Two key parts of a compressor are the inducer and the exducer. The inducer (sometimes called the minor diameter) is the part of the wheel that first takes a "bite" of ambient air. The exducer (sometimes called the major diameter) is the part of the wheel that "shoots" the air--now compressed--out of the turbo. Just remember that the inducer is where the air comes in and the exducer is where the air exits. Got it? Good.
You need to understand those two terms in order to grasp the concept of trim, a bizarre bit of tech-speak which is often thrown about. Trim is simply a term to describe the size of a specific compressor within a family of wheels. It can be expressed in abstract ways (such as when Turbonetics says they have P-trims, Q-trims, etc) or you can use the actual numeric measurement (50 trim, 57 trim, etc). Here's how you calculate the measurement:
Trim = (minor diameter / major diameter) ^2 * 100
So now we have a way to perform some math and get a number. What does it all mean? Generally speaking, the larger the trim the more flow the wheel will have. Nevertheless, one should not rely solely on a trim measurement when selecting a compressor wheel! Find out specific wheel measurements (inducer and exducer), understand how subtle differences will affect airflow and response, and then choose a wheel accordingly.
Speaking of subtle differences, let's take a look at them. First, the inducers:
What happens when you upgrade to a larger inducer while retaining the same exducer? The most notable change is more airflow capability; since the turbo is taking a bigger "bite" of air in every revolution, it can obviously "spit out" more air as well. Gee, more airflow aounds great... so why not go to the biggest inducer you can find? Because that creates two main problems, one much more important than the other. The smaller problem--really it's just a nuisance--is the turbo will now have a little more lag during spoolup (because the bigger wheel weighs more, plus it has to do more work with each revolution, etc). While this extra lag might not be noticed on a dyno--all the bystanders will be oohing and ahhing at the huge top-end horsepower such a turbo would produce--it would make for dissatisfaction in your day-to-day drive and could even cause you to lose a drag race to a car with less peak horsepower but more area "under the curve" due to his turbo that spools sooner. The real trouble with a large inducer increase but no exducer increase, though, is it makes the turbo much more likely to surge. Surge is the situation when the compressor "spits out" more air than the engine can swallow, which causes a backup of air at the intake and it actually creates reverse-flowing pressure waves that can be very damaging to the turbo. You want to avoid surge at all costs.
Okay, so maybe we won't go hog nuts wild with the inducer. How 'bout the exducer? Let's take a look:
When you upsize the exducer without modifying the inducer, the exact opposite effect happens: your spoolup time is reduced. Why does this happen? Remember that a compressor "spits out" the air in a radial fashion. The larger exducer gives a higher wheel edge speed for a given shaft speed, and that higher edge speed means the compressed air exits at a higher speed than before... and thus it builds boost faster. Another effect of this upgrade is an increase of the compressor's pressure ratio capability without a significant increase in its maximum flow rate; we'll discuss these more later on.
So now let's tie it all together. If you want more power with similar response, look for an upgrade of both diameters. The larger inducer will net you more airflow and thus greater power capability, while the larger exducer keeps boost response within reason and lessens the chance of surge.
(Stop and take a deep breath--you've digested a lot of info.)
Thanks to TurboMinivan.com
Old Jan 5, 2009 | 07:52 PM
MRaynor's Avatar
Old Jan 5, 2009 | 09:29 PM
midnite><og's Avatar
bad *** read. ive always had an interest in turbos, and now i understand them more. just need to figure out how to take apart the two i have laying around the house
Old Jan 5, 2009 | 10:21 PM
busta's Avatar
Thank You Bobby
a very good read
Old Jan 5, 2009 | 11:18 PM
Old Jan 6, 2009 | 01:35 PM
kazairl's Avatar
Didn't see it mentioned here so I thought I would throw this out there.
Since the INducer is where the air comes in and the EXducer is where it exits(get it? IN and EXit) the INducer of the Compressor wheel is the smaller part while the EXducer is the bigger. But remember on the TURBINE wheel it's the exact opposite. The INducer is the bigger part of the wheel while the EXducer is the smaller part.
Old Jan 24, 2009 | 10:02 AM
Originally Posted by Rutru5652
The shopkeeper was dismayed when a brand new business much like his own opened up next door and erected a huge sign which read BEST DEALSHe was horrified when another competitor opened up on his right, and announced its arrival with an even larger sign, reading LOWEST PRICES. The shopkeeper was panicked, until he got an idea. He put the biggest sign of all over his own shop-it read... Main entranceIf you need sell cheap wow gold,you can buy wow power leveling on the website: buy wow gold, cheap WoW Power Leveling, sale wow Gold, 1-80 lvl wow power leveling, wotlk gold.
Old Apr 3, 2009 | 12:03 AM
jamiewood's Avatar
Site Sponsor - Southern Diesel Extreme
Lets dig this back up. So we use the example 62/71/14. Were do these #'s end up compared to inducer/exducer?
Old Apr 3, 2009 | 08:49 AM
RSWORDS's Avatar
62 would be the inducer of the compressor wheel it would be 62mm
The 71 would be the inducer of the exhaust wheel it would be 71mm
and the 14 is teh exhaust housing in cm2
Old Apr 4, 2009 | 12:59 AM
jamiewood's Avatar
Ok, How about measuring the foots....T3, T4, etc...
