VW Diesels Discussion of all things Volkswagen Diesel - TDI, Bug , Touareg , Jetta , Golf , Passat
Common TDI Bombs
Old Nov 22, 2008 | 09:42 PM
Woody35's Avatar
Default Common TDI Bombs
Heres some upgrades for TDIs
VW Diesel Engine Tuning and Upgrade Guide - Diesel Dynamite - Eurotuner Magazine
VW Diesel Engine Tuning and Upgrade Guide - Intake and Exhaust - Eurotuner Magazine
Justin Fivella Looks At Tuning Options For The Existing Vw Diesel Engines.
While most would consider the VR6, 1.8T or 2.0T the go-fast engine of choice for their Volkswagen, an army of Dubheads in Europe (and even some here) march to a different beat; a sooty "clattery-clack" beat.
We're talking the other white meat, the bottom-of-the barrel sippers; we're talking diesels, baby!
This JSP Mk4 ALH diesel owned by Lance and Candace Koch from Canada runs low 15sec quarters
With redlines in the neighborhood of 5000rpm, they may not spin like a gas engine, but stump-pulling torque makes these oil-burners a viable alternative to their gas-burning brethren. And before you join the chorus of cliches that are traditionally associated with these fossil fuel alternates, why not have your cake and eat it with nearly 200whp and over 300 lb-ft plus 40mpg, too...
Brief History
Gone are the days of the loud, sooty, slow Mk1 diesels that managed a paltry 50hp. In fact, these days you'd be hard pressed to know you were driving a diesel, such are the wonders of modern technology. And while VW has stuffed diesel motors in just about every platform after the Mk1, most of the modified diesels you'll find in the US are on the Mk4 platform. Therefore, we'll focus on that chassis for this article.
The first VW diesel to shine in the states used the '96-03 BEP TDI (Turbocharged Direct Injection) motor. However, we will discount the '96-99 AHU variant and focus on the '99.5-03 ALH motor - a true workhorse, these later 1.9 liter motors are stout, to say the least, and came with 85hp and 130 lb-ft at the wheels from the factory, according to JS Performance.
The motor remained relatively unchanged until '04, when VW decided to replace it with the short-lived Pumpe Duce (non-TDI) VEW engine. These used an in-house design similar to the latest "common-rail" technology and spray fuel at over 20,000psi into the combustion chamber for more power and lower emissions.
While the future of the newer VEW engines looks bright, the BEP motor presently dominates the market. And rightly so, with tuners like KermaTDI and JS Performance continuing to push the performance envelope.
But there are still hurdles to overcome, and modern diesels must still fight the preconception that they're slow, smoky and smelly. However, VW has strived to perfect the diesel so that smoke is virtually non-existent (except at start-up) and passing power is plentiful.
Largely overlooked in the US, it's only in recent years that tuners have realized that VW diesels can rival the potential of the 1.8T and 2.0T motors, while returning over 40mpg.
Tuning
Like the 1.8T/2.0T engines, a simple software upgrade, along with the standard bolt-ons, can net significant power and torque gains on a diesel. Where a 1.8T can expect a 30% increase in power, the BEP diesels can nearly double their outputs with similar mods.
Traditionally, people begin tuning their gas-engine cars by uncorking the intake and exhaust sides, followed by tuning the ECU. The succession then usually progresses to a bigger turbo and, eventually, a built motor.
Most start modding with a set of bigger nozzles, like these from JSP
After talking to both Kerma and JSP, we learned that relieving the intake and exhaust on a diesel, without proper tuning, can actually hurt its performance. A diesel might be an internal-combustion motor, but Kerma and JSP warn newbies against applying gas-engine logic to diesel motors.
With the parts available for the 1.9 TDI, achieving 200whp from your diesel is considered a respectable feat. And while 200hp might not seem much, remember that a diesel in that neighborhood will be making over 300 lb-ft of axle-snapping torque to the wheels.
In general, most people on the street will see 150-175whp, with 270-320 lb-ft of torque without any loss of drivability, while returning over 600 miles to a tank of fuel.
Following Kerma and JSP's proven recipes for power, we'd recommend you start with a matched nozzle and ECU upgrade. This will typically net around 130-140whp and over 200 lb-ft.
Companies like JSP sell affordable flash-loaders that allow infinite tuning options and impressive gains
KermaTDI Wagon - wouldn't that be nice?
New turbo technology is giving diesels good top-end performance with the expected bottom-end torque, too
VW is introducing the TDI cup race series this year
You'd never know this oil-burner is packing a big turbo and full bolt-ons
This Kerma-built head and turbo assembly with custom intake manifold and tubular exhaust manifold will extract serious power from the big turbo
Next in line is a clutch, because the factory unit is usually toast by then. At this point, most enthusiasts call it a day, happy with the output - the car remains quiet and economy is intact.
But like most of you, we'd never stop there. So next would be a bigger downpipe and exhaust, along with either a different cat or cat-delete. These mods generally max-out the turbo at 150whp and around 220 lb-ft. The open exhaust adds a muscular Mac truck-like sound as the turbo-spool becomes more apparent.
The next step is an upgraded turbo like a VNT17 or VNT20, which will take you into the region of 160-185whp and over 260 lb-ft with the aforementioned mods.
While these straightforward additions can double your power and torque, it isn't without its problems. Both Kerma and JSP stressed that the transmissions are the single biggest hurdle to modifying these cars because nothing can withstand that much low-end torque.
Most of us realize that a VRT or big-turbo 1.8T will eat its gearbox for lunch, but the diesels can exceed 300 lb-ft at around 1500rpm - a violent collision of axle-snapping, gear-grinding torque.
You've been warned; if you turn to the darkside, you'll quickly get really proficient at swapping your transmission!
Chili Pepper Racing's VEW-powered Jetta diesel is on of the few competitive diesel racecars in the US
Racing Diesels
In case you've been living under a rock, Audi won the 24 hours of LeMans with their diesel-equipped racecars. Proving these robust engines are every bit as competitive as gas engines has put the racing world on notice. And equally impressive are smaller diesel programs like Chili Pepper Racing (CPR) and its fleet of Jetta diesel racecars.
Although new to the sport and pioneering diesel racing in the states, CPR is gaining early success. Driver and President Jim Osborn explained that since little is known about building VW diesel race motors here, they've had to forge their own way. "If it wasn't for the help of some European tuners, we wouldn't be where we are today. They know so much about diesel tuning over there, while we know virtually nothing," Jim said.
Kerma suggests a downpipe with software can produce good gains
Despite the steep learning curve and the lack of aftermarket support at their level, Jim said the indestructible nature of the diesel and its massive torque fit right in. "We're able to take an over-the-counter engine from VW with stock internals and turn it into a racecar - that's impressive when you consider most of our competitors have thousands of dollars in their engine alone," Jim said.
With a stock block, Jim also retains the stock nozzles but adds an unspecified VNT Garrett turbo, an in-house FMIC, downpipe and exhaust. They also have custom ECU tuning to extract the most from these parts.
"Because of our torque, we're able to run a higher gear through corners and save four or five shifts per lap. This translates into roughly half a second per lap; that's a lot."
Ignore them if you wish, but one day you might get spanked by a diesel. And when it happens, remember we told you so!
After your typical bolt-ons, a larger turbo will get you near 200whp
The Future
The future is bright for diesel, thanks to the threat of $5 gas making 40mpg from a fast car appear enticing. Both JSP and Kerma explained how new hybrid turbo technology is allowing them to exceed 200whp and 320 lb-ft in street-driven cars. These new Garrett turbos are allowing diesels to carry power at high revs like a gas engine, while still retaining the earth-turning torque.
Diesels are here to stay. Companies like Audi have shown these engines can be fierce competitors. And while it's nice to know diesels can win on the track, both Kerma and JSP expressed their excitement for the latest VW diesel technology arriving this year.
Elsewhere in this issue you can read about the turbo-diesels that are arriving over the next few months and learn about their tuning potential based on what's already happening in Europe.
Old Nov 22, 2008 | 09:52 PM
Buckshotmckee's Avatar
Sma't Alec!
Old Nov 23, 2008 | 02:32 AM
Lostnwalmart's Avatar
hmm a 200 hp jetta sounds sexy.... im goin to have to talk to kerma
Old Nov 23, 2008 | 02:21 PM
Woody35's Avatar
get ready to pay. the things i would to do my car if i had money
Old Nov 28, 2008 | 10:43 PM
Patrick@DPP's Avatar
Looking at a n 09 right now. Getting bent over on the Cummins though. May not happen.
wow! Go on the TDIClub and they are all scared when I talked about removing the DPF, and tuning a new car. I told them we do it all the time to trucks. You have to watch what kinda questions you ask . May be a bunch of tree huggers or something?
Last edited by Patrick@DPP; Nov 28, 2008 at 10:43 PM. Reason: Automerged Doublepost
Old Nov 29, 2008 | 04:41 AM
mishkaya's Avatar
The reason for that is probably because the engine is a new design; and thus there is still a lot to learn about it. TDIclub is a very good resource for the Volkswagens as far as I am concerned. Love my '06 Jetta!
mishkaya
Old Nov 29, 2008 | 06:27 PM
Woody35's Avatar
alright they have a lot of info about TDI's but as soon as you talk about smoke or getting rid of emissions they flip. oh aother thing they dont like to answer common questions like we do on here. they just say to look for it . pisses me off because its hard to get reliable answers on there
Old Nov 29, 2008 | 10:54 PM
Tell me about it. I have been reading that forum for two days now. I think I know less about them than when I started.
Here is my question Woody...If I buy an 09 Jetta TDi can I bomb it, and what would you do? What can they handle, and am I going to plug the DPF quick if I do bomb it?
thx
Old Nov 30, 2008 | 01:32 PM
Woody35's Avatar
so i was reading a little about on the tdi club and i guess the only thing right now is a module that you plug in. now information on it plugging up DPF's and throwing codes is not known right now because the car is soo new. im sure there will be stuff later but it is just so new like 1.5 months since these things have come out. a module will be fine for the tranny it will not hurt it.
Old Dec 17, 2008 | 08:41 PM
G60ING's Avatar
My DZSL SLC was in that very same EuroTuner Issue. Yes the VR6 and turbo gas motors are no longer the most conveted. Hell I yanked a VR out of my first TDI Corrado and I'm about to yank a VR6 out of a mk3 Golf in afew weeks so I can install a TDI
Right now the 09s are still under development for chip tunes but VW had the TDICUP cars up to 170whp with a reprogram and a filter back exhaust.
