cummins fuel plate
Old Nov 19, 2008 | 06:36 PM
dan33klein's Avatar
Default cummins fuel plate
Hi guys, i have a 1996 12 valve and i am looking to put a fuel plate in it, i normally just use it for driving around but i want a little more power for heavy towing and just showing off sometimes.. what # of fuel plate should i get?
thanks
Old Nov 19, 2008 | 06:38 PM
ltr450's Avatar
put a #0 plate in it
Old Nov 19, 2008 | 06:40 PM
dan33klein's Avatar
dont you have to adjust the governor then??
thanks
Old Nov 19, 2008 | 06:41 PM
ltr450's Avatar
or you could just slide stock one forward
Old Nov 19, 2008 | 06:45 PM
dan33klein's Avatar
the stock fuel plate?
what # can i get to give me a boost but just drop it in and go
no modificatiions?
Old Nov 19, 2008 | 06:53 PM
ltr450's Avatar
you pump has a stock fuel plate in it. you can move it all the way forward then back it up 1/16 of and inch. you could put a #10 or #100 in it. more boost you can pinch off waste gate line.
Old Nov 19, 2008 | 06:55 PM
dan33klein's Avatar
soo i can put a #10 in it and i will gain some power, but not need any adjusting or modifications?
Old Nov 19, 2008 | 07:05 PM
ltr450's Avatar
no you should be ok with #10 or #100 but go easy on trans. is your truck stock.
Old Nov 19, 2008 | 08:26 PM
How heavy do you tow??
Id say a #10 for slid most of the way forward for screwing around, and then when you want to tow heavy, back it off some.
Old Nov 19, 2008 | 10:07 PM
dan33klein's Avatar
my trucks pretty much stock.
i got a 5spd manual in it.
so i should probably get a #10 fuel plate?
thanks
