loosing oil
Old Nov 13, 2008 | 05:06 PM
99_f250's Avatar
Default loosing oil
ok so my truck has been leakin oil, and i think its because the oil drain plug is old...which i hope but look whats its been causing... its because i got an oil change at this shop which i found out was half ***...they put 5 quarts of oil in it..and i bet they didnt change the drain plug..DAMN ********!!!
http://xc7.xanga.com/8e9f11722273322...w172838343.jpg
http://xa2.xanga.com/0abf02716253222...w172838337.jpg
http://x88.xanga.com/027f1172d1c3322...w172838336.jpg
http://x6e.xanga.com/1e2c9b7b44c3022...w172838334.jpg
http://x3d.xanga.com/a25c6b774423122...w172838333.jpg
Old Nov 13, 2008 | 05:15 PM
gunman41mag's Avatar
Moderator
You mean 15 quarts of oil !!!!!
Old Nov 13, 2008 | 05:18 PM
99_f250's Avatar
i know its 15 well 18 but he only put 5...which i almost whooped his ***. cause my truck almost got ruined cause i didnt know he only put 5...
Whit's Avatar
Site Mascot
you prolly need a new seal washer on yer plug
you can hook up a vacuum on yer fill hole and pull the plug without loosing a drop ........................or you can just change the gasket next oil change
Old Nov 13, 2008 | 05:19 PM
99_f250's Avatar
really the vacuum thing works?
Old Nov 13, 2008 | 05:21 PM
Whit's Avatar
Site Mascot
yes it does..........you can make alot of beer money on this bet
Old Nov 13, 2008 | 05:22 PM
99_f250's Avatar
hahah damn im gonna try that..so just were u put the oil in put a vacuum pump there and just take off the plug and then nothing comes out hahah man if u wouldnt have told me i would have bet you too
Old Nov 13, 2008 | 05:25 PM
Whit's Avatar
Site Mascot
a good shop vac will do the trick just fine...............make sure you bet yer buddy as you will need help on this....................2 man job yaknow
Old Nov 13, 2008 | 05:26 PM
99_f250's Avatar
since theres a drain hole and oxygen can come in it goes through the oil and into the vac so the oil doesnt go in the vac right?
Old Nov 13, 2008 | 05:29 PM
Whit's Avatar
Site Mascot
the oil will be down in the pan and the vac wont be able to suck it up from that far
