can anyone tell me what this is
Old Nov 13, 2008 | 05:02 PM
99_f250's Avatar
Default can anyone tell me what this is
because theres oil in it and ive heard the crystal inside of it makes sure no oil comes in the sensor and when it goes bad youll see oil in the sensor... oh yea notice the oil to the right of it..
http://xd3.xanga.com/c59f074342c3222...w172838240.jpg
Old Nov 13, 2008 | 05:04 PM
Whit's Avatar
Site Mascot
I bet its yer oil pressure sender.......disconnect the wiring and see if you still show oil pressure maybe
Old Nov 13, 2008 | 05:07 PM
99_f250's Avatar
when i disconnect it the check engine comes on...but theres oil inside the sensor..
Old Nov 13, 2008 | 05:10 PM
Whit's Avatar
Site Mascot
so is yer oil pressure reading showing ???
is this sensor threaded in or does it have a hold down tab with an O- ring seal
Old Nov 13, 2008 | 05:11 PM
99_f250's Avatar
it has an o ring and its still showing....
Old Nov 13, 2008 | 05:15 PM
Whit's Avatar
Site Mascot
I would pull it out and get a new O-ring to seal off the oil leak
it must be a sensor for something else if yer still showin oil pressure
maybe is it water temp?
Old Nov 13, 2008 | 05:17 PM
99_f250's Avatar
well it goes right on the head... but ill try a new o ring first
Old Nov 13, 2008 | 06:06 PM
CSIPSD's Avatar
Its your ICP sensor... So there is no oil in the connecton? Might pull it and check the O ring, but if there is oil in the plug the sensor is done. Its what tells the PCM how much ICP is in the rail.
Old Dec 7, 2008 | 03:18 PM
camojeeper@gmail.com's Avatar
not sure how many miles you got on you rig but i would just change it out with a new one there is an updated design
steve
Old Jan 2, 2009 | 12:03 PM
RowdyRacks's Avatar
Once theres oil in that sensor its done and you need to replace it. They even have a pig tail wiring kit to replace the electric plug part of it as well if you got oil up in the wiring harness. Warning its not cheap I think dealer cost for me was around 160.00.
