General Diesel Related Tech Articles For all things that pertain to Diesel.
HOW TO: Propane
Old Oct 16, 2008 | 01:29 PM
dontneedtostroke's Avatar
Default HOW TO: Propane
Propane:
When Propane is added to the air intake usually the horn it ensures that all the Diesel is turned into Power.
When propane is used properly, it will keep your engine cleaner with less carbon buildup and cleaner oil. Propane is a high-octane fuel and burns slower and longer therefore, propane will help diesel burn more thoroughly, increasing horse power and torque. With propane your engine should last longer, get better fuel economy and have significantly more power.
By fumigating the air intake with propane, there are dramatic increases in horse power, torque and diesel mileage. Exhaust temperatures are only slightly increased and in many cases decreased. It is one of the safest horsepower increases on the market.
Diesel Performance Products LLC:
POWERSHOT 2000™ PROPANE INJECTION KIT
The Powershot 2000® propane injection system for turbo diesel owners who are looking for more power for towing increased mileage and throttle responsiveness out of their vehicles.
With it's innovative and patented design and method of propane delivery, this system is unique to other systems on the market and has overcome many of the drawbacks encountered with earlier designed injection systems.
The Powershot is an infinitely variable-stage vapor injection system. It is controlled, activated and proportionate to the boost pressure of the engine. The Powershot comes on slow and steady and as the boost increases, so does the flow of propane. More boost=more propane=more power! It is fully adjustable and can be customized for your specific application in minutes for towing, performance or mileage gains.
The easy-to-install Powershot system will safely and substantially increase horsepower (up to 100hp) and torque (up to 250 ft lbs). This unit is a must for towing and all- around performance increases. Modest mileage gains are an extra bonus.
The system installs in about two hours and requires no permanent modifications to the vehicle or engine. The quality of the components is obvious: Custom LP regulators /Parker fittings, safety features such as custom auto/off rocker switches located inside the cab, and an automotive LP fuel lock-off solenoid valve located at the tank. All of the regulating is done at the tank eliminating the need for under hood installations and further enhancing safety concerns. The custom regulator maintains a constant tank pressure regardless of outside temperatures and delivers consistent, usable power at all boost levels.
Powershot 2000™ Propane Injection kit for turbo charged diesel engines by Diesel Performance Products:
* Optimizes engine performance by increasing throttle response, torque and horsepower.
* Increases fuel mileage.
* Can decrease diesel emissions-fuel burns cleaner, oil stays cleaner
* Improves towing capabilities.
* Simple, patent pending design provides for easy installation and virtually no maintenance.
* No Hobbs switches, converters, mixers or sensors to adjust or hassle with.
* Makes your truck FUN TO DRIVE. - Guaranteed!
Bully Dog Propane Charger
Propane Kit 80 hp (adjustable) #010800
DOWNLOAD INSTALL MANUAL
DIY:
Do It Yourself
Supplies:
1 20lb propane bottle
1 acetylene gas regulator (any wielding shop will have it, its a low flow regulator and fits perfectly to propane bottle)$60-$70
1 propane flow valve for a propane fueled car or truck (any propane gas company can order it, its a simple on off valve with a solenoid)$30
1 standard automotive toggle switch ($2)
1 roll of teflon tape or fitting sealant ($2)
1 pack of 12" zip ties ($2)
1 roll of red wire ($3)standard automotive wire
1 roll of black wire ($3)
12-28ft of hydraulic hose with 1/4" fittings on each end (you need to measure how many feet of hose you will need, from where tank will set to air box) Also get it in two different sections, both with male-male fittings (you will see why later)
2 washers, 1 lock washer, 1 nut to fit the end of hose where it is inserted into air box
Ok, now to to put it together.
Drill hole in airbox so the 1/4" fitting of one of the male-male hoses so it fits into the airbox. Put one flat washer on outside of fitting and on the inside put the other flat washer, then the lock washer and the nylon lock nut. (I will leave out stuff like, "tighten the nut" in the instructions)
Ok, now run the hose down the back of the motor and under the truck along the frame using zip ties to secure it. When you get to the other end of the male-male fitting put the propane valve on (its has female 1/4" fittings on each end) Put Teflon tape in the male end of hose and tighten "TAP" (tight as possible).
Ok, now take the red wire you bought and secure it to the screw on top of valve solenoid (only real place it can go) run the rest of the red wire into the cab of truck (we will come back to toggle switch)
Ok, now connect the male end of your other male-male to the valve with teflon tape and "TAP", then run it along the frame to the place where you put the tank. Put Teflon tape on that end and secure it into regulator using "TAP".
Now go into cab and wire up your toggle switch, I use the toggle switch that lights up when the circuit is open or on.
Now connect the regulator to tank and turn on gas (make sure the truck is "NOT" running) Turn the regulator until about 4psi is showing on gauge.
Make sure the toggle switch is off and start truck, THEN THE MOMENT OF TRUTH, flick the switch, you will notice the engine difference. If you don't notice a difference then the switch is not wired right.
Turn switch off, get on hwy and flick the switch, you will notice a slight difference. Pull over and turn up psi .5 and do it again. Do this until you find the right psi setting for your truck. Usually between 4-7psi, if engine makes a slight pinging noise then turn the psi DOWN .5
Thats it, of course how much propane you use depends on how much you use it. I get pulling a load in hills around 300-500 miles or so. When you need a boost of pwr turn it on and when your need for the xtra power is done turn it off.
Now alittle info about propane and diesel. Propane is a very stable and mild gas. It gives diesel fuel the ability to give a complete burn. This means more power and a cleaner engine. Hydraulic hose works great, its about $2 a foot and you can get it made at most auto parts stores. Stop and think about it, hydrolic hose is rated to handle thousands of psi and all you are running is 4-7psi. It is both wire and rubber mesh. Propane will not harm it in any way. If you are nervious you can add a "flash back" fitting to this (get it where you got the regulator) it stops any flame from reach the tank through the hose. I do not use one, but that's me.
The total time took to rig it up was 2hrs. The toggle switch was the hardest thing for me and they are easy. So if I can do it you can. It saved me $800 on a "pro" setup. Of course how you secure your tanks is up to you. I keep mine in my tool box and the hose runs out the botton of it.
The propane when turned on flows into the airbox and is sucked into the engine, yes mine is a turbo and it will not harm it or ignite it. Propane really is very stable.
thought this would help out anyone thinkin about propane...
RESOURCE: DM
Old Oct 16, 2008 | 02:45 PM
slowtowpig's Avatar
thats awesome.
Old Oct 16, 2008 | 03:15 PM
Whit's Avatar
Site Mascot
good job thanks for the contribution bud
Old Oct 16, 2008 | 03:53 PM
i spent like a week week and a half looking for a DIY article on this and i finally found one and what do you know! DM wrote it
Old Oct 18, 2008 | 09:36 PM
supersportjim's Avatar
awesome. i think i might have to give this a shot. does anyone have pics of the install?
Old Oct 18, 2008 | 10:00 PM
Lil Red Express's Avatar
I think this thread should be a STICKY. Thats great info Thanks.
Old Oct 19, 2008 | 06:58 PM
no pics yet probably in the next week or two when i myself actually get it installed
Old Nov 7, 2008 | 12:41 PM
AlCorr's Avatar
WOW, I really like this, Thanks.
Can I run the propane hose to my Banks air intake horn?
Pictures would be excellent!
Old Nov 7, 2008 | 10:38 PM
i got it all hooked up but i have a problem...when the switch is shut off the gauge tops out and when you switch it on its a big jolt than pretty much nothing...i will figure it all out then post up the pics
im not sure about the intake horn... all you have to do is drill a hole in your intake tube... that to me would be easier but you have to get an answer from someone more knowledgeable about this stuff...im more of a second hand resource
Last edited by dontneedtostroke; Nov 7, 2008 at 10:38 PM. Reason: Automerged Doublepost
Old Nov 7, 2008 | 10:39 PM
stkdram55's Avatar
sounds like ya need to adjust the regulator or something along those lines
