abs wont work
Old Oct 16, 2008 | 10:21 AM
94cummins12v's Avatar
Default abs wont work
i cant figure out why my ABS is not working on my truck. i already know my rear brake shoes are toast because people dont disengage the parking brake before they drive it, so could that be a problem. i noticed it about a week ago when i hit my brakes and my front tires locked up. i dont want this anymore since winter is on its way. doest anyone have any ideas to this problem
Old Oct 16, 2008 | 10:35 AM
Whit's Avatar
Site Mascot
do the rear brakes and change the fluid out while yer at it then see what happens from there
here is some help, I did this and its well well worth it man
https://www.dieselbombers.com/cummin...e-upgrade.html
Old Oct 16, 2008 | 11:52 PM
well i dont get it the front tires locked up on me yesterday and now when i slam on the pedal the front tires dont lock up, this is wierd
Old Oct 26, 2008 | 12:43 PM
MRaynor's Avatar
Any resolution?
Old Oct 26, 2008 | 03:02 PM
Whit's Avatar
Site Mascot
did you go thru the rear brakes and get them working again???
Old Oct 27, 2008 | 07:34 AM
cameroneod's Avatar
If its set up like my 03 you may have a problem with the sensors. Mine were cracked and would make/lose the connection alternatively. Is there a dummy light coming on at all?
Old Oct 27, 2008 | 11:00 AM
well i put new shoes on, the light is still on but now i dont even hit my breaks hard enough to lock them up with this exhaust brake
Old Oct 27, 2008 | 05:55 PM
Thanks - Im starting this tonight (....in the dark ).
Old Oct 27, 2008 | 07:07 PM
Benjamin's Avatar
Bombardier
does your truck have 4 wheel ABS or just Rear Wheel ABS? mine has rear wheel ABS....
Old Oct 27, 2008 | 08:14 PM
you know i couldnt tell ya if its just the rear or all four it was made in may of 94 if that means a thing
