2003 F250 6.0 Stumbles At About 3000 RPM
Old Sep 27, 2008 | 03:58 PM
skilleddd's Avatar
Question 2003 F250 6.0 Stumbles At About 3000 RPM
Hello all,
I have been having an issue that I cant seem to figure out. 03 6.0 is starting to to stumble severly when the rpm gets around 3000 and the turbo really spools up. I have changed the oil in the truck and at appropriate level and I have taken the EGR out and cleaned all the soot from it and made sure that it wasnt rattling, I have also changed out the fuel filters both lower rail and engine topside. It doesnt stumble as much as it did before after I did all these things. I can still fill the stumble slightly. I recently had the HPOP go out and replaced by a dealer in Florida who stripped out 4 valve cover bolts and 1 oil rail bolt. My local dealer had to helio all these last week to fix the oil leak. I have put an SCT Xcal 2 programmer on it and it is not throwing any codes. Any body have any possible solutions to this issue I would greatly appreciate them. I apologize in advance if there is a thread already containing this, but I have searched through them but may not be using the right terms to find my answer.
Thanks
Old Sep 27, 2008 | 03:59 PM
Does it do this with and without the SCT downloaded?
Old Sep 27, 2008 | 05:43 PM
skilleddd's Avatar
yes it does, I just last week got the programmer, and I actually was having this issue when it was set to stock. I programmed it with an economy tune and it still did it, so I changed it back and still same issues.
Old Sep 30, 2008 | 08:18 AM
skilleddd's Avatar
ok upate after doing all that work to the truck, I put the stock program back in the truck and drove it for a day and it has cleared itself of all the problems. SO would it be possible that the tunes I am loading be giving the truck fits?
Old Sep 30, 2008 | 02:33 PM
Its possible to cause probelms if your SCT Tunes are the incorrect strategy code.
Old Oct 1, 2008 | 09:46 PM
skilleddd's Avatar
Thanks I will verify the strategy code again and check it against the tunes
Old Oct 20, 2008 | 10:01 AM
2500HeavyDuty's Avatar
Bump, did you get this fixed?
Old Oct 26, 2008 | 12:47 PM
MRaynor's Avatar
Since there has been no response, we will assume that this issue is fixed. If need be, this thread can be reopened.
Thesinnest
Nov 6, 2015 10:40 AM
cgraham
Aug 4, 2015 07:50 PM
irozchris
Mar 14, 2015 11:16 PM
alex74708
Dec 28, 2014 04:18 PM
2003powerstroke6.0
Oct 19, 2014 10:04 PM
