What Tire Pressure On 35 Toyo MT's
Old Sep 9, 2008 | 11:34 AM
nmlakerat's Avatar
Default What Tire Pressure On 35 Toyo MT's
what tire pressure you guys running on your 35 toyo mt's been playing with the pressure trying to find the best all around running psi.
Old Sep 9, 2008 | 01:02 PM
Johnny Cetane's Avatar
I can only offer you general advice but:
Take a grease pencil or some chalk and draw it across the tread. Then drive the truck a head a bit and see how the chalk wears.
To get the best mileage (life & mpg) you basically want to air the tires up to the point just before the chalk starts to stay on the tread at the edges.
So if at 45 psi you see chalk left on the outer edges then lower it down to 42 and try it.
I bet you'll be around 35 psi or so.
Old Sep 9, 2008 | 04:00 PM
slowtowpig's Avatar
around 40 on mine.
dallasca
28
May 26, 2015 12:58 AM
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
veggyoilkid
Nov 10, 2014 12:39 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
