P0299 Turbocharger Underboost DTC
Old Sep 3, 2008 | 01:25 PM
vwdieseljunkie's Avatar
Default P0299 Turbocharger Underboost DTC
Been battling this for a few weeks now. Here's the background info:
2005 Ram 2500 4x4 w/5.9l 24v
AFE stg II intake showing NO blockage, MBRP freeflow out back showing NO backpressure.
Bullydog tripledog w' outlook monitor, latest version dl'ed for tripledog.
Normal boost high reading - 21psi
Normal pre-turbo EGT reading - 1400* at WOT and 21psi boost
Normal 75mph level cruise - 7psi @ 800* EGT
Current boost high reading - 10psi w/o cel, 3psi w/ cel
Current 75mph level cruise - 2psi @ 900* EGT w/o cel, Nothing over 65mph w/ cel
Truck is otherwise stock for powertrain, and has been bullet proof and reliable until now. I am a light-footed driver anyways and enjoy high MPG's with this setup.
P0299 cel pops up, puts everything into limp mode. EGT's go crazy and Boost won't exceed 3psi. Erase code, limp mode goes away, egt's still higher than normal and boost topping at 10psi until code comes back with limp mode. Turbo sounds like it's dumping boost. Made a boot for the turbo with air valve and gauge, regulated 15psi input and soaked everything with soapy water, NO charged air leak from turbo to intake. Wastegate linkage can be worked back and forth, no sticking points. ZERO backpressure at down pipe. Freshly reconditioned AFE filter.
Turbo feels good from the cold side, no slop or play, good spin with fingers, looks good, nothing shiny (that shouldn't be), haven't dropped the down pipe to inspect the hot side.
Only guess I have is possibly a faulty MAP sensor? I have unloaded programmer, returned to stock, still throws the code. Might be coincidence, but code usually shows up while attempting interstate on-ramp. EGT's will hit 1250 (my defuel setting on outlook) and keep climbing, and if I don't let out of it I watched it hit 16** and began to sweat.
I did some searching, found some similar problems with other folks here, same truck, same programmer, same situations it seems, but never a fix.
Is the MAP sensor the only thing manipulating the turbo-to-computer communication? Anyone remember how much one of those cost? Maybe know what this thing is supposed to read across a multimeter?
Old Sep 3, 2008 | 03:08 PM
wildbill's Avatar
Possible Causes:
OTHER DTC’S
INTAKE AIR SYSTEM RESTRICTION
TURBO CHARGER DAMAGED
INTAKE AIR SYSTEM LEAK
BOOST PRESSURE SENSOR
TURBOCHARGER
INTERMITTENT CONDITION
1. OTHER DTC’S
Turn the ignition on.
With the scan tool, read the Engine DTC’s.
Do you have other DTC’s?
Yes >> Repair other boost related DTC’s first.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC
CONTROL MODULES/ENGINE CONTROL MODULE - DIAGNOSIS AND TESTING)
No >> Go To 2
2. INTAKE AIR SYSTEM RESTRICTION
Inspect the air filter and intake air system for signs of restriction.
Were any restrictions found?
Yes >> Replace the Air Filter or repair the Intake air system for restriction.
No >> Go To 3
3. TURBO CHARGER DAMAGED
Disconnect the air cleaner connection to the turbo charger.
Using the service manual as a guide, visually inspect the turbo charger blades and turbo housing for signs of damage.
Was any damaged found?
Yes >> Replace The Turbo charger.
No >> Go To 4
4. INTAKE AIR SYSTEM LEAK
Using Miller Special tool # 9022, pressurize the intake air system and inspect for leakage.
Use the service manual as a guide.
Were any leaks detected?
Yes >> Repair leaking intake air system.
No >> Go To 5
5. BOOST PRESSURE SENSOR
Using the scan tool, compare the boost pressure sensor reading with the ambient air pressure sensor with the ignition
turned on.
Are the boost pressure and ambient air pressure sensors within 6 in hg of each other?
Yes >> Go To 6
No >> Replace the Boost pressure sensor.
6. BOOST PRESSURE SENSOR
Turn the ignition off.
Install Miller special tool #9022.
Ignition on, engine not running.
Use the scan tool and compare boost pressure reading to the regulated air pressure for tool #9022.
NOTE: The reading on the boost pressure sensor may be slightly lower than the regulated pressure.
Does the boost pressure sensor reading increase with the regulated air pressure?
Yes >> Go To 7
No >> Replace the Boost Pressure sensor.
7. TURBOCHARGER
Disconnect the exhaust outlet connection.
Visually inspect the Wastegate flap in the turbocharger turbine housing
Is the Wastegate seized in the open position?
Yes >> Replace the Turbocharger.
No >> Test Complete.
Old Sep 3, 2008 | 04:14 PM
stkdram55's Avatar
Old Sep 4, 2008 | 07:51 PM
Does anyone have an exploded view of the Holsett turbo?
Old Sep 4, 2008 | 09:19 PM
DB Admin's Avatar
Banned
There nothing wrong with your charger , sounds like its the MAP
Unplug it Clean the Connection and plug it back in
Old Sep 8, 2008 | 09:10 PM
MRaynor's Avatar
Did you find out what was wrong?
Old Sep 12, 2008 | 08:24 AM
Double checked the connections, outlook monitor actually plugs in between harness and map sensor, all look good. Funny thing, overhead console display has gone lazy, doesn't power up with ignition, and takes it's sweet time to wake up, sometimes several miles down road before it pops on. I'm going to run through all my fuses and check for bad connections or corrosion. This has got to be a computer/electrical issue. I knew better than to get away from manual diesels that need five or less wires to operate.
Still playing with it. I need to find out what kind of signal the MAP sends out so I can diagnose it without simply buying another to see if it works. With all the fuel expenditure involved in all these hurricane evacuations, my budget is pretty tight right now until things return to normal.
Funny, I always get limp mode on the way TO work, never on the way home. Maybe my truck is trying to tell me something
Last edited by vwdieseljunkie; Sep 12, 2008 at 08:24 AM. Reason: Automerged Doublepost
Old Sep 12, 2008 | 08:37 AM
Oilfield_Mafia's Avatar
Overhead display as in the Outlook Monitor? or as In the Stock overhead Display? Have you tried unloading the Bullydog and monitor? Return the ECM back to stock, unplug the monitor and Bullydog, and see if the problem still exists.. If not, then I would say you found your issue.
Old Sep 12, 2008 | 09:03 AM
Stock overhead display. I have done a complete return to stock including uninstalling the outlook monitor. After confirming that the issue continues in complete stockness... I re-installed the outlook for obvious reasons, so I could monitor boost and egt's. I have not yet re-installed the programmer, and won't until I solve the underboost issue. Egt's are hot enough as they are.
I'm thinking about seeing if anyone local has a boost-fooler I can borrow just to see what effect it has on the issue. If it lets the turbo boost up, that puts me one step closer to just going ahead and buying a new map sensor.
Old Sep 12, 2008 | 09:51 AM
wildbill's Avatar
Another member is having the same issue. He pulled the MAP out and cleaned it. Says the code hasn't come back, yet anyway.
